Originally Posted by
bcarithers
How does everyone think this compares to the BenQ W7k? I have the BenQ and it is pretty nice minus the blacks so I am thinking about moving to the Mits if the blacks can justify the added cost...
Also will DLP link glasses work with the Mits?
im not familiar with the black levels of the w7000. Art says the HC8000 just edges out the blacks of the Panasonic ae8000 which sounds about right to me as it seems just under my old TW9000 ..
I doubt the HC8000 would be worth the upgrade unless it didnt up costing much. You would take take a hit in the brightness too. Id like to be able to have a look at the w7000 to tell you how much of an upgrade it woud be
Universal glasses such as the Xpands will work, or the Genuine ones designed specifically for the projector. The latter being the best bet as they let in more light than the universal ones.
