I have had this receiver since 1999, so it has served me well. Although it does not have the latest decoding, connections, and switching, I bet that its sound quality matches most current receivers in its category.....My blueray has analog outputs for Dolby/DTS true HD, so that DD for satellite and other sources works just fine. I mean, if I could still squeeze some use out of it I will....
The problem is that it appears that whenever I attempt to use a digital connection, optical or coax, the receiver won't produce any sound. Watching closely, the "lock" red pilot light on the display does not light up. I connected thru the analog input, and sometimes it won't work for a while. Upon keeping trying I get it to work, mostly.
I changed the optical cables to discard this was the problem. I also "reseted" the receiver processor following the instructions on the manual, w/o success.
I wonder if anyone has experienced this problem and if there is a fix, short of sending it for repair, which I won't do..
At this moment I am thinking of an upgrade, but if I can defer it further, I will...
Thanks for your help.......
