Originally Posted by
purbeastÂ
So I experienced something just now for the first time on this projector, and it's not a good thing.
I was playing my Xbox 360 and was playing some Forza Horizon when the screen went black for a second. The sound was still coming out of my speakers so the AVR was still getting signal from the 360. It came back on like a second later and I was like wtf so I paused it and got up, like if someone was messing around with me. Then like 4-5 more times, the screen went off then back on, like a second or so off then back on. It happened like every 5-8 seconds or so, then stopped.
I started playing again and then the screen went black again for a second then back on. It happened only 1 more time after that. I continued to play for like 15 more minutes and had my camera ready to take a video if it happened again but it didn't.
Has anyone seen this happen? Is this the dreaded "flicker" problem from the 7000 that I had heard about?
On another note, today is the first day I had my projector hooked up with the serial cable to a GC-100 device, and I'm now controlling it with Roomie Remote. Could that have anything to do with it?
I probably have like 150 hours on the projector if that is any info that would help. I can check the exact hours tomorrow.
This blows happening the day before the Super Bowl...
I just wanted to give an update on this, because I saw this issue 2 more times since then, and I was looking for just a little bit more input before I try to pinpoint down what this is.
The following day of my previous post was superbowl sunday and we watched the game for 4 hours or so straight with no flickering. I was then listening to some music on pandora on my receiver, and noticed it happened again. So this wasn't on the 360 input, it was on another one.
Last night I was playing PS3 and this happened more than once again, like 30 minutes in. And I only played about 90 minutes total. It was frustrating as hell and I tried messing with some HDMI cables.
I currently have a 25' HDMI cable from my projector in the wall to a wall jack in a closet. From that wall jack I have another HDMI cable connected to my receiver. then I have a bunch of HDMI cables running to the other components. Also, the 25' cable I'm using now is the same one that I had been using for a month or so before I did the in-wall wiring and never had this issue.
So I swapped the hdmi cable going from the wall jack to the AVR, since I had seen this issue on 3 separate inputs. it seemed to fix the problem, but then I saw the flicker happen 2 more times. They didn't happen in succession like the previous ones did, but they happened.
I also tried using the other HDMI output on my receiver, with the original cable, and saw this issue as well.
So does anyone have any other suggestions on what to trouble shoot if I see this popping up again? Luckily I did run another HDMI cable in the wall so last resort, I will take the faceplates off the walls and try plugging the other HDMI cable into the projector. But I kind of want to get rid of all other possibilities before I go that route.
Has anyone heard of these HDMI wall jacks causing issues like this? Also, could running my HDMI cables (the ones that go to the components and AVR, not the in wall one) right along with the power cables that plug into the wall cause something like this? I always figured that if something was messed up with the HDMI cable, that the sound wouldn't come from the HDMI cable either.
Or could this be caused from a heating issue? The first 2 days this happened it didn't happen for at least 3 hours of components being on, although last night it happened within an hour, so I'm not sure if that coudl be the culprit.
