AVS › AVS Forum › Audio › Speakers › Revel Concerta F12 vs Energy RC-70
post #1 of 3
How do these speakers compare? Will be using them for music and movies with a dedicated subwoofer
post #2 of 3
They will both sound great.
I would get the Revel since it has more pedigree being related to the $22,000 Revel Salon2 and $70,000 JBL Everest, plus all that research from Harman International's Floyd Toole and Sean Olive. biggrin.gif
The Revel will have a better resale value.
post #3 of 3
Only a little familiar with that Revel model so take this with a grain of salt (as you should with all internet reviews):
The Revels are probably fairly neutral.
The Energys are "warm", ie, some mid- and upper-bass emphasis.
This of course will be at least in part room and placement dependent, but I would expect it to hold true as a generalization.
Which you prefer is, well, up to you. Both should be pretty good speakers, just with a somewhat different character.
  Back to Forum: Speakers
