AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › LED TV for Gaming under 500?
post #1 of 4
I've been doing some research and stumbled across some threads that led me to this site. I figured I might as well use the search button which I did, but what I have noticed was all the tv's people have been wanting have been in the 700+ range... I'm kinda low on money,but I want to set up a nice gaming station in my room. That brings me to my question is there an LED 42" TV with low input lag for under 500? Any brand is fine as long as it's worth its bang for its buck. So far I've read that Sharp has little to no input lag, I don't know if this is true or not, and also that plasmas tend to have burn in which result from an image being in one place for too long and burning into the screen itself. Seeing as how i'm going to using this for gaming 99% of the time I want to try and stay away from them if possible.
Thanks for any help given, it would be really appreciated!
post #2 of 4
perhaps the UN40EH5000, though it's a bit pricier
post #3 of 4
Yea this tv seems really nice! I bet I could get it used or refurbished for under 500! Thanks again, if you have any other suggestions it would appreciated!
post #4 of 4
TCL makes a 40". Reviews say no lag and that it uses a Samsung panel.
