So I'm doing a small extension to my house and one addition is a 17x12 family room. Keep in mind that this is not a dedicated home theater room or anything like that. Just a family room/den that will have a TV and hopefully a nice 5.1 or 7.1 audio setup. I'm attaching a picture of the room drawing but there's really no detail to it. It's just a rectangle with windows and a large opening. The flooring will be hardwood, possible with a rug, and it will be built on top of a crawl space.
I'm trying to figure out how to design the rear speakers. I assume I'll just use a standard center channel and front speaker set (either bookshelf or floor standing depending on budget) together with the TV stand on the top wall in the middle (part by the 11'7" in the picture). But I don't want wires or clutter for the rear speakers. I'm figuring that the couch/seating will run parallel with the top wall about 13' or so away from the top wall.
Initially I was planning in wall speakers on the sides for the 5.1 surrounds and then in wall speakers on the back wall for the 7.1 surrounds. But as you see the opening to the room is on the left side so I can't use in wall speakers where no wall exists. So my current thought process is to put in-ceiling speakers for the 5.1 surrounds above the ends of the couch and then still use the in-wall speakers on the back wall behind the couch to complete the 7.1 surround sound.
So any comments on the above? How would the in ceiling and in wall speakers mesh? Should I just dump the 7.1 idea and go with 5.1, and if so which sets of speakers do I dump?
I'm not doing personally (not that handy) doing any of the actual construction but will probably do the speaker wiring for the 4 rear speakers. I'll do the wiring before the drywall goes up so I'm not imagining too many issues there and I might even use brackets for the in-wall and in-ceiling speakers so I don't have to cut any drywall after the fact. Any thoughts on the project? Any thing I'm missing here?
Thanks for all the help.
