AVS › AVS Forum › Audio › Receivers, Amps, and Processors › VSX-921-k compatible cd player
post #1 of 2
I just purchased this receiver and after much work eveything is perfect. My cd player is so old I can't find any code to hook it up to the remote. I want to buy a new cd player and be able to use it through the remote. Can't stand not being able to turn it on or switch cds and songs. What are some good ideas to purchase? I want a multiple player not just 1 cd. Thanks.
post #2 of 2
I've had this Onkyo 6 disc changer for at least 7 years now. Never had a problem with it and bought a refurb from this vendor for the same price.
http://www.accessories4less.com/make-a-store/item/ONKDXC390/Onkyo-DX-C390-6-disc-Carousel-Cd-Changer/1.html
I also have a much older Sony CD 5 disc changer that has worked well for me.
One of these Denons might appeal to you too.
http://www.accessories4less.com/make-a-store/item/DENDCM390/DENON-DCM-390-5-Disc-CD-Carousel-w/Built-in-HDCD-Decoding/1.html
http://www.accessories4less.com/make-a-store/item/DENDCM290/DENON-DCM-290-CD/CD-R/RW-5-Disc-Changer/1.html
