AVS › AVS Forum › Video Components › Video Processors › Convert NES from 240p to 480i?
post #1 of 6
I've tried a bunch of searching with no luck, hopefully this is an easy one:
I'm trying to upconvert an NES 240p signal (I have a second gen NES with composite output) to 480i so that my fancy-shmancy receiver can pump it to my TV through HDMI.
Does such a thing exist?
post #2 of 6
No, a tool for 240p to 480i does not exist - at least not in a single step.
Pick up a line doubler with component output (e.g. an iScan Pro for about $40-50). it will take the 240p and output 480p component which your receiver can then convert to HDMI.
post #3 of 6
Ugh, of course.
The receiver I have can upconvert 480i (over composite or component) to HDMI, or (obviously) any HDMI input. No 480p or 720 over component.
Is there... a way to convert the NES to HDMI? Doesn't really matter the resolution. :\
Thanks for the help, by the way. This issue is just proving to be far more... let's say "dynamic" than I thought. haha
post #4 of 6
Really ? Seems weird to me that an AV receiver has HDMI output, but can't process a 480p component input.
NES to HDMI: same as above. Get a cheap line doubler to get 240p to analogue 480p and then use a VGA to HDMI or component to HDMI converter to get it to your TV. Good VGA or component to HDMI boxes will run you roughly $40 as well. You can check my signature for other affordable scalers which might to the same in a single step. Expect to pay a little more though.
post #5 of 6
Yeah dude, check it out. It's totally messed up.
http://i.imgur.com/iUTOI.png
post #6 of 6
Bumping this thread, to link to some videos.
Ian recently approached me with basically the same problem (240p capture on a HDPVR) and I recommended the same thing I did here. He decided to upgrade to the HD-PVR2 (with HDMI input) and to use an old DVDO processor (a VP20) as a "recording interface".
So, here's his setup: http://www.youtube.com/watch?v=pLwkCB55wvc
and here're two recordings, one in 480p, one in 720p, both a classic 240p videogame source.
http://www.youtube.com/watch?v=DrOyMOl-_EQ
http://www.youtube.com/watch?v=ra-hOH8arVA
Quite awesome I would say!
  Back to Forum: Video Processors
