Question.... do the wireless speakers or wireless transmitters work well for rear speakers? I imagine getting the speakers mounted in the back of the room would be costly to get the wall cut and wire run. So i was thinking the wireless route. also is it ideal to have the speakers about head height or should they be in the ceiling?
Sort of looking at different options. If i have to get the cable run i see they have speakers that sit in the ceiling and have a cover that sits in the ceiling as well.
If it helps I can take pictures of the area to show for reference.
