Just that question alone should be easy to answer but it's a bit more complicated than that...
I'm trying to build a decent 2 channel system for my g/f using second hand parts. She wants to listen to CDs and FM-radio.
I found a couple of Canton GLE490 3-way floor standing speakers http://www.canton.de/en/archiv/produkt/gle490.htm a couple of days ago.
Now I'm trying to find a receiver (or amp plus tuner) to drive these speakers well and a matching CD-player.
When looking at the second hand market here in Sweden I've found the NAD C740 (2x35W continuous at 8 ohm) and NAD C720BEE (2x50W continous at 8 ohm) stereo receivers.
However I've also found a couple of older NAD surround receivers that have higher 2ch specs than these stereo receivers(T743(2x70W, T744(2x70) and T753(2x90W)).
So my question is: Would a surround sound receiver like the T753 with a 2ch spec of 2x90W be better than a stereoreceiver like the C720BEE with 2x50W?
I've also looked at Cambridge Audio amps and CD-players and found the 640A(2x65W) and 650A(2x75W) along with the 640C or 640D players. How would these compare to the NAD receivers I mentioned?
Of course with these I'm missing the FM part so I'd need a tuner as well.
But then I found the 540R surround receiver with a 2ch spec of 2x100W along with a 540D player. So then I'm back to the same question as in my headline except now with Cambridge parts.
Suggestions??
Suggestions??
2x200W continous power, 120 amps...
