AVS › AVS Forum › Display Devices › Display Calibration › Samsung 8000 has green tint
post #1 of 5
I just received my Samsung 8000. Out of the box, the picture has a slight greenish cast to it. Adjusting the red-green balance does not help it.
What are the settings I should play with to address this issue?
Thank-you.
post #2 of 5
Thank-you.
without a meter/software, you'll want to toggle between various color temp presets until it disappears or is minimized (probably Warm1 or Warm2... Cool and Standard will be far too blue)
post #3 of 5
Would decreasing the green gain or increasing the red gain address the issue?
post #4 of 5
hello
What picture mode is out of the box?
from the comments on the owner's side, and several review sites, I would only use "Standard" and "Movie", both with Warm2 settings.
From all the reports I have seen, the Standard and Movie modes were never too green: Nitra had too much red, and badwilly and myself had too much blue.
There is not much response on this thread. I have seen that you are also on the owner's thread, and as there is more life there, you might get more feedback there.
post #5 of 5
not a good idea without a meter/software... try Movie mode with Warm2 or Warm1
