Originally Posted by KDH
I belive this to be untrue. Professional reviewers work on the veiwing side of things. I work on the other side. I have over 30 yrs experience adjusting convergence and it is always sharper with better convergence.
You can test for your self. Go ahead and converge using the test grid. globly if that works and indapendent zone as well if you like. Now take a seat. watch the picture. go to the menu and you can turn it off and on to see the difference back to back. If it is convegered properly then it will be sharper with it on. The idea that they use no electronic convergence from the factory is absurd. They most certinaly do. Those pannels are not perfect and are never alined perfectely,
They just dont let you to that service menu. Now they have brought it out so the user can fine tune it to perfection.
if my memoy serves me right when you go into the zone adjusments with the 5020 there are already corrections there. Most of the time (like with the sony) they hide the factory corrections so u start at a 0. Most manfactuers do it that way.
It is not untrue. If one could align the pixel mechanically or actually control the electron beam lighting the phosphers in a CRT FP, your statement would be true. Unfortunately we have three fixed panels. And there is nothing that one can do to align them correctly after less than perfect alignment by the factory when building the light engine. also with cheap lenses of narrow diameter, using lens shift cause chromatic aberration of the red grean and blue colors appearing as the same effect of misconvergence but causing the amount of non alignment of the pixels to vary accross the picture.
what the manufsactures do is to provide you toos to hide you from seeing it. By shifting colors where they should be located on tyhe grid. This is OK when done in full pixel increments causing only a loss of one line from the direction shifted from. using subpixel adjustments this causes using two pixels to do the job of obe with the worst case being a shift of 1/2 pixel. You pick up the space between pixels causing a loss of sharpness as well as a loss of resolution. The Sony manual warns about these affects and at least when the feature was first introduced, not to use it things really get messy when multiple zones are independently adjusted. Generally, the professional reviewers like WGR think a net benefit may be obtained by subpixel shifts done globally of no more than say a 1/4 pixel. you mauy dissagree but you are wrong.
what it doers it shut dissastified customers up. see its fixed.
