AVS › AVS Forum › Audio › Speakers › Wall Mount Brackets and Recommended speaker placement for Energy Take 5.1 Classic
post #1 of 2
Hello
Can you pls. recommend any good (but inexpensive) speaker wall mount brackets for front/center and rear energy take 5.1 classic speakers?
Also are the front 2 speakers supposed to be at ear level (sitting down) and the center also should be below the tv (if tv is wall mounted)?
AVR
post #2 of 2
fwiw, go to monoprice and look under speaker mounts there should be something for you there and yes your fronts should ideally be at ear level and also the center closest to ear level as possible or pointed down towards you.the rears just sligtly behind your seating about5-6ft above.pointed downward slightly towards you
Edited by smasher50 - 10/6/12 at 3:16pm
  Back to Forum: Speakers
