I have been planning a basement project for a while and now I am on to the electrical. From what I have read I plan on using ISY-994I and Insteon. (All new framing and electrical)
Here is my thinking in a effort to minimize cost.
Should I wire only one switchlinc dimmer to each light fixture(or group of light fixtures). Then in order to gain a light control at each entry I could replace one switchlinc dimmer with a Keypadlinc dimmer. So theoretically I could control 8 groups of lights from three locations using 5 switchlinc dimmers and 3 keypadlinc dimmers. Instead of using 8x3 or 16 switchlinc dimmers. This would free up some Insteon cost, some switch wall space and some switch wiring.
This Is not exactly my final plan as I would not need to control all 8 lights from all three locations. And some of the locations will have the primary switchlinc dimmer so I would not maximize my Keypadlinc.
I just want to know if this plan makes sense in theory. Is it a bad plan to limit the wiring of a home and need to count on a technology such as Insteon to make the space functional. Or is it reasonable to think that this technology or similar will be around for a long time.
All thoughts are appreciated.
