Originally Posted by
Wheels_32
Thanks for all the input guys.
I know itunes is supposed to be easy, but I have really struggled with it. One of my daughters has an ipod...and it just does not seem easy.
Anything unfamiliar takes practice. None of the other options are any better, they're all different. IMHO iTunes is more intuitive and therefore easier than most others. You just have to use it a little every day.
Wheels_32
It is unclear to me if I can have all of my music, plus all the music for my kids...and only synch her ipod with certain songs, but not all, etc.
You can sync each iDevice with customized settings. So, if you want only your daughter's music on her iPod, you just select it before you sync her iPod. You can also let her have her own completely separate iTunes library, and keep all your music separate. All this information and more is available on the Apple support pages, but you're always free to ask here too.
Wheels_32
I also don't know if itunes will allow dumping some of the songs from this collection on my wife's Android phone, or if it only works with Apple products?
iTunes will only sync with Apple products, but that doesn't mean you can't get music from iTunes onto your wife's Android. You can.
http://www.addictivetips.com/windows-tips/sync-non-ipod-mp3-players-with-itunes-using-itunes-agent/
Wheels_32
Regarding the Airport Express you have mentioned - how is that different than Sonos system? Which is better?
Thanks again!
Think of iTunes as a stereo system and Airport Express as an extension speaker. Airport Express uses an technology called AirPlay. You can have any number of devices that support AirPlay, such as Airport Express, Apple TV, many modern AV Receivers have AirPlay built it, and there are even AirPlay powered speakers. Any AirPlay device is a destination for iTunes to play to. You can select which destinations you're playing to with a little drop menu in iTunes, and you can even have individual volume controls for each device.
http://www.apple.com/itunes/airplay/
Think of each Sonos devuce as a stereo system playing from one collection of music. Each Sonos device will play music independently from all others, or it can play the same music at the same time, your choice. The main advantage is that each Sonos device is a player, not just an extension speaker. That comes at a cost, and a fairly high one at that. There's a lot in each Sonos device, and many times that includes an amp and speaker, or an amp and wireless speakers. Sonos is much more expensive, but you do get flexibility. You still have to have all your music in an iTunes library, and the computer that has it must be running, and on a network.
Back to iTunes for a sec. If you set up an AirPlay device like an Airport Express, or Apple TV, or an Airport AVR, you can also play music to that device wirelessly from an iPhone, iPod Touch or iPad. It's kind of nice when friends come over and want to play the latest tune through your system. No cable required. Also, you can control iTunes from any of those devices using Apple's free Remote app. And, if you use Pandora, it will also play to any AirPlay device. Its pretty hard to beat. With an iPad or any WiFi iDevice, you can also play from your library independently, sort of Sonos style, using Apple's Home Sharing technology. Once you've set up Home Sharing, your library is available to any other computer on your network running iTunes, as well as any iPad, iPhone or iPod Touch. That's a lot of capability for basically free, not counting AirPlay devices, and why I usually recommend a system built around it. Sonos basically gives you independent players with built in speakers (they do make a line output device too), and if you need that it's a bit more simple to operate, but lots more expensive.
