AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Energy S10.3 Subwoofer Auto Power Mode Problem
post #1 of 3
I just got my Energy S10.3 Subwoofer from Newegg earlier this week. I have it hooked up via the subwoofer out on my Denon 1613 in which I've run the Audyssey setup with the mic positions as such:
............................. FRONT
_______.______4_____________5_______.______
llll....................l......................l....................llll
llll........ 3 .......-l.......... 1 .......-l........ 2 .......-llll
llll______.______l_______.______l______.______llll
lllllllllllllllllllllllllllllllllllll-lllllllllllllllllllllllllllllllllll-lllllllllllllllllllllllllllllllllllll
\lllllllllllllllllllllllllllllllllll-lllllllllllllllllllllllllllllllllll-lllllllllllllllllllllllllllllllllll/
................................. 6
.............................. BACK
I absolutely cannot get the Auto power mode to work consistently, so to avoid having to get up and manually flip to to "On", I just leave it there for the majority of the time until I feel like trying Auto again. From what little documented cases there are on this issue online, a few conclusions have been drawn: an internal wiring problem with the amp or send it back under warranty with shipping on my dime.
At an estimated $40 to return ship it back, I don't think that investing 20% of the original cost is worth it without further troubleshooting first.
Can anyone give any insight as to what things I can do to work this out or is better I just suck it up and go through Newegg's warranty?
Karson
post #2 of 3
FYI, you should be running Audyssey in the following positions:
4 -- 5 -- 6
3 -- 1 -- 2
Re. your sub's auto-on function, it's possible that it's not consistently receiving enough signal from your AVR to trigger it. According to your AVR's speaker set-up menu, what level has Audyssey set the subwoofer to?
post #3 of 3
4 -- 5 -- 6
3 -- 1 -- 2
This. See what Audyssey set your sub at and raise it if needed. You can always run Audyssey again to see if that helps out your problem.
