This is a litle OT, but it may address the question of why the affinity for horns.
Horns project the sound as opposed to the listener having to chase the sound. You can kick back in your chair and the sound comes and finds you. This is a good thing.
This is a dream come true for me, i love Cinema and simulate a Home Theater at my house is fantastic.
I also want to tank you all for your opinions, critics and help. Seriosly, if it weren't y guys i would have gone with the Sub from Klipsch, and i am very happy to go with SVS...
MANY MANY TANKS
Now i have a small problem and i need help here... I have the Pioneer SC-LX90 (Amp) and according to the photo of the back of the Amp and also the back of the SVS Sub what is the best way to connect them?
On the Monitor Audio RX-W12 i only had a single cable from the AMp to the Sub, but i think the SVS 13 Ultra is a bit more complex....
SVS Back.jpg 243k .jpg fileSC-LX90.jpg 324k .jpg file
Use the subwoofer 1 out that is right under your HDMI #5 and connect it to the SVS to either the left or right input, it really doesn't make any difference. Then follow the instructions on how to set up your subwoofer in the manual. ( I hope SVS has a Portuguese section). How fluent is your Espanol? I'm sure they have the instructions in Spanish.
No problem with the Spanish
I was thinking on buying then a "Stereo adapter" for sub connection. Or will it assume it as such even with one socket on only?
It's already decided and ordered, however i apreciate your opinion.
The THX Ultra 2 Kit doesn't have better sound than the speakers i've ordered (I didn't ordered Martin Logan, i've ordered Klipsch RF), i've listened to both. Besides it's for a Living Room, the THX set are like "Boxes", good only for dedicated rooms. Edited by MV_Cinema - 10/20/12 at 1:55am
