AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Fot HT which is better POLK PSW505 OR BIC F12
post #1 of 15
hello guys i have denon 1612 and energy classic take 5 and im missing the sub which of the two should work do on my set up? Mostly for movies and daily shows. Thanks.
post #2 of 15
i have the f12 and i love it but most people here from what i read say the polk is slightly better for music.
i think they might also say that both those subs would probably be too much for the take five. that they would overpower the energys.
im betting most people here would recommend one of these two cheaper subs instead
dayton 1000, 10 inch sub
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-628
or dayton 1200, 12 inch sub
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-629
post #3 of 15
that is what i thought, i think those speakers the polk 505 and bic f12 will overmatch my small speakers, how about the polk psw10?
post #4 of 15
forget about the polk psw10. that is the least recommended budget sub on avs.
go for one of the daytons i recommended.
post #5 of 15
what about the BIC F12 and Polk PSW505? not for music but HT. either one is good?
post #6 of 15
I like the PSW505 over the Bic f12 for $200
post #7 of 15
what about this compare to polk505 http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-629 i always use it for movies not into music.
post #8 of 15
My choice still rest with the Polk at the $200 price range I have has personal experience with that subwoofer versus the Bic H100(similar to F12)
The Dayton is cheaper, you want to save a few bucks take a risk I doubt you'll be disappointed
post #9 of 15
I've had the BIC v-1220 (down firing, similar - i think - to the f12 which is front?) for about a year and a half.
It rattles my house, is effective for music, but really shines for TV/Movies/Gaming. For <$190 it's a very good unit that you can build/upgrade around (the 10" version is ~155)
just an alternate opinion to those already stated.
good luck, and may your pictures never hang straight again!
post #10 of 15
thanks. i will buy this one now. what cord i need to buy for this to connect to my denon 1612 receiver? thanks.
post #11 of 15
anybody can give me any idea? good for $200 budget descent subwoofer? anybody can recommend?
Edited by caloyzki - 10/9/12 at 12:56pm
post #12 of 15
Something like this.
anybody can give me any idea? good for $200 budget descent receiver? anybody can recommend?
Don't you already own a Denon AVR-1612? That's a decent receiver.
post #13 of 15
im sorry not receiver. subwoofer. i went to newegg. but the psw505 the price is 249 now frown.gif. anything else besides that? i dont want to buy at amazon tax kills me. smile.gif
post #14 of 15
I've been looking at the BIC F12 and PSW505 as well. Seems these two subs are interchangeable based off who you ask in these forums. Is this a correct statement?
post #15 of 15
Go for dayton 1200.
