Samsung HLT5075SX/XAA 50" DLP HDTV - approx 5 years old 7100 hrs
2 months ago my bulb blew...
Thinking I would save some money, I used a generic bulb - it lasted 2 weeks and blew
Thinking it was bad luck, I had them swap it out under warranty - it last 1.5 weeks and blew
There were no other problems with the TV, no noises, never shut down on its own... etc.
I decided to buy an OEM Phillips bulb and a new ballast as a last ditch effort to save my TV
The new ballast and new bulb are in, the TV starts right up, but now it shuts off after it gets warm (approx 10 min). All three lights flash, and won't turn back on unless you unplug, and plug back in, then it only lasts about 1-2min before shutting down with the same 3 lights flashing.
In order to troubleshoot, I bypassed the temp sensor, and the bulb door switches, reset the bulb timer, swapped back in the original ballast....Also, unplugged all the inputs and TV still acts the same, no change...during all this troubleshooting there were 2 days where the TV worked perfectly, but then returned to this behavior....
Now I'm stuck...I don't know if the bulb is crap after it gets hot and I need to get 'another' bulb...or is something else gone wrong.
The fans work, all dust has been removed, the color wheels spins and makes no abnormal noises...
FYI the DMD board was replaced approx 1 year ago when I called samsung about the 'white spots' issue...
