AVS › AVS Forum › Video Components › Video Processors › Need a video recorder
post #1 of 3
Hope this is the correct forum for my problem.
I am in charge of recording our church's services every week. We have two video cameras that send to an A/V mixer with outputs to individual monitors and to an old DVD recorder. The DVD recorder is on its last leg and is giving us huge problems so I need to replace it.
What I would like is a video recorder that takes either S-video or composite video inputs, has at least one composite video output for monitoring and records to internal storage that can be copied to a thumb drive or maybe records to a removable SD card or something like that, so I can take it home and edit it for web deployment.
Thanks in advance.
post #2 of 3
You should probably post this question in the HTPC forum. A video card on a computer sounds like what you would need. Something like this, but I don't think it has plain composite out:
http://www.directron.com/haup1191.html
post #3 of 3
Thanks for the suggestion, but I would prefer to not use a PC. Was hoping there was a stand alone recorder that would fit my needs.
  Back to Forum: Video Processors
