I've searched for this but get bits and pieces so I thought I'd seek advice on my exact issue/question.
After sliding down the HT slippery slope I decided to upgrade my 2 channel set up. To that end I've purchased a set of Salk Songtowers and a Jolida intigrated tube amp.
I just recentley built my home and pre wired so that I have an AV closet with speaker wires running into the living room (where I will do my 2 channel listening). We do most of our listening through our squeezebox duet using Pandora or CD ripped (MP3 format) into my office PC.
When I first got the speakers and amp home (bought them from the same guy) I put the amp on the floor (not realistic long term), plugged Oppo BDP-83 to amp, ran wires from amp to Salks and thought it sounded great.
My question is this. Would you?
a. Go from the AV reciever (Pioneer Elite VSX-23) pre-out to the intigrated amp to the speakers using the existing, in wall, wires. This keeps all gear in closet.
b. Use the intigrated amp on Zone 2 of the AV reciever?
c. Hook the tube amp directley to the speakers from the AV closet. This option becomes an issue of ease of operation for other (wife) family members.
Is there a huge differance from direct CD to MP3 through squeezebox? I know I could set up the different scenarios but it is time consuming and doesn't nec. allow A/B comparisons on the spot.
Thanks for your input.
Jamie
Jamie
