Hi all,
I'm looking for a relatively "easy to use" simple remote to keep in the bedroom that will work with my existing MRF-350 and RFX-250 antenna. I'm already using an MX-850 in the "home theater" type room.
In this setup I have an existing HDMI switch going in to an Onkyo 7.1 receiver, and out from Onkyo to a 65" LCD.
I ran HDMI to a wall-mounted plasma in the bedroom and want to be able to control at least a few of the components from the bedroom as well as IR direct to the TV for power on/off and volume. Mainly I want to be able to control the FIOS STB (Motorola QIP-6416 I believe) but other components would be nice. So that I can have multiple inputs and output to both the theater TV and the bedroom, I'll probably be picking up an HDMI matrix switcher like this one -- it has an IR sensor so at a minimum I can teach the MX-850 the codes and it should work out ok I think.
Also I would like to stay relatively cheap if possible ... like well under $100 if possible
Anyone have recommendations for a simple URC IR+RF remote that will work with my existing base that could solve this purpose?
Right now I'm actually looking into like the RF-10 / RF-20 to see if it would work (still not sure) but would actually prefer something much more simple if possible (e.g. like the old MX-200 but could do IR+RF with the MRF-350). It would be great if I could program it using MX Editor software like I already do my MX-850 but that is not 100% required
Another option I have thought about: getting something like a NextGen IR Extender
for the bedroom TV and just use the FIOS remote with it, then use the MX-850 or really any other multi-device programmable remote in the theater with IR only (all components are behind glass doors within easy line of sight so IR should be fine). Bad part about this I guess is that I wouldn't be able to also possibly control other devices (including the HDMI matrix) from bedroom if I wanted to possibly have other sources feeding in there.
Any leads would be appreciated!
