AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › What do you guys use to attach IR emitters to your equipment?
post #1 of 9
Hi all,
In most of my installations there's at least one device (namely the cable box), that requires an ugly IR emitter stuck on the front of the device. I remember in my early days of low-end installations that the Harmony RF repeater came with handy adhesive squares that held the emitters in place more securely. Is there anything out there that I can purchase for this purpose? There's gotta be a cleaner way than electrical tape to secure an emitter---the adhesive that's on there never lasts long, and that's a silly service call!
post #2 of 9
I have open several of my units to install inside the emiter, that's the cleanest and harder way
post #3 of 9
HD and Lowe's carry a heavy duty, gray, double- sided, foam mounting tape. It come in small rolls with a red plastic cover over the adhesive. Unlike the cheap white foam tape with the green/white paper cover, this tape stays strong and does not dry out. It reaches maximum hold strength in about a week. A little extra heat helps to activate the adhesive. A hair dryer does quite nicely
post #4 of 9
Thanks for the quick replies. I'm sure opening the box and installing the emitter inside works, but that's not a realistic solution for me or my guys. The double sided foam sounds like a solution, but it does sound kinda ugly. Are there any issues with the IR passing through the foam?
I really can't believe there is no solution specifically made for IR emitters out there... Any body else?
post #5 of 9
Have you looked here?
What you attach emitters with doesn't have to be transparent, just pass IR. Only way to find out is to try
FWIW I don't attach emitters to my gear. I attach them to the cabinet the gear is in. You can pretty much use whatever kind of adhesive you want then.
post #6 of 9
Thanks for the help. That's what I was looking for!
post #7 of 9
My FIOS cisco dvr has a port on the back marked "ir". Would this be a seriel connection for ir control? Has anyone used this to control their FIOS dvr with roomie or irule using iTach adapters?
post #8 of 9
post #9 of 9
I use hot melt glue. Never falls off but you can pry it off if you need to
  Back to Forum: Tweaks and Do-It-Yourself
