AVS › AVS Forum › Display Devices › Flat Panels General and OLED Technology › Gamer Looking For The Final 2012 Word
Gamer Looking For The Final 2012 Word - Page 3
post #61 of 64
Is there even an LCD HDTV that can input 120hz natively? On a side note, wow! An 120hz capable "IPS" monitor? That's first for me!
post #62 of 64
Originally Posted by Mark Rejhon View Post
Alas, the lines are blurred there too. (pun!) LCD monitors and LCD HDTV's can have the same advantages and disadvantages. There is generally less input lag in computer monitors, though the most laggy computer monitors have more input lag than the "Game Mode" of some of the least-laggy HDTV's. So there's sometimes overlap. In addition, high-priced HDTV's have motion enhancements and local dimming, that computer monitors do not. So the question is not very clear cut.
But there's some generalities. Computer monitors almost always have less input lag -- that's one thing you usually can count on. And there's more computer monitors that can accept a native 120Hz input, than HDTV's that accept a native 120Hz input. The largest computer monitors are 27" to 30". If you're computer gaming, then I'd suggest going for 120Hz, both because of motion blur and also because you get less input lag with 120Hz than 60Hz. And you'll like the reduced motion blur.
You won't get the "sharp motion" of full motion interpolation found in the better HDTV's like the XBR950, but that's usually not desirable for computers, due to input lag, anyway. However, you can gain 120Hz and little input lag. One of the ultimate these days, right now, is the Catleap 2B overclocked monitors from 120hz.net (120Hz native IPS 27 inch, at 2560x1440!). You really need at least a Geforce GTX 680 or similar to drive 1440p@120Hz though -- and that will set you back plenty. 1440p@120Hz is an overclocked resolution, that overclocks both the monitor and the graphics card, so don't buy if you prefer something more widely supported -- then go for 1080p@120Hz from one of the familiar names (Samsung, Asus, Acer, Benq, etc)
Thanks for this detailed info Mark ! Yea, looks like for me, I made the right choice with the TV I got. I've been over happy with it since I got it, and now hearing this just makes me feel like there really couldn't have been a better option at 55" and above. Seriously, my expectations for this TV have been exceeded in every way.
post #63 of 64
Be warned, 2560x1440p @ 120Hz (the IPS 120hz.net Catleap 2B monitor) requires quite the GPU monster -- you'll easily just about break four figures when you buy the monitor and the GPU necessary to run video games at 120fps at that resolution.
Oh, and I've now started a list of full sized HDTV's that can do 120Hz via the refresh rate overclock technique:
List of full size HDTV's that can be forced to 120Hz native refresh rate from a computer
We need more guinea pigs to connect their computers to all kinds of HDTV's following the refresh rate overclock instructions (force-ignoring the DDC 60Hz limit and sending 120Hz anyway)
Edited by Mark Rejhon - 11/8/12 at 12:28am
post #64 of 64
The refresh rate of the panel is independent of the framerate. The only impact the monitor should have it what resolution you run it at.
Actually, at 120hz, even if you've got v-sync enabled, you should get less lag than at 60hz with the same videocard and cpu, due to the framebuffer update latency being reduced from 16ms to 8ms.
