AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Is the Denon 891 still worthy?
post #1 of 8
My old receiver is starting to act up, like not sending sound to the surrounds anymore.
I have a boston acoustics 5.1 in a box combo but have bigger matching speakers for the mains. a blu ray player and a HD dish receiver. the display is a 60" sharp, no 3d..
Is the denon 891 still a good receiver at the price they are selling for refurbished? or should I go for something like the 1612 or1712?
edit--- or maybe the 791 would be fine for me
thanks mark
Edited by mark62 - 10/9/12 at 3:26am
post #2 of 8
It's better than the 1612, but the 1712 offers the more advanced version of Audyssey MultEQ XT.
post #3 of 8
so the 1712 or 1912 would be better? I edited my post to add the equipment im using...
post #4 of 8
The 1912 features the same version of Audyssey as the 891, although adds networking, so you need to choose the model that best meets your requirements.
post #5 of 8
i dont need networking and i have no exp. with multEQ... really i was just thinking about getting the 1312, but i read the xx12 thread and leaves me thinking if i really need the multEQ as i never had it before and my speakers are sub $500....
post #6 of 8
does the 1712 equal the 891 in sound quality and besides the multEQ XT on the 1712, do they basically have the same dacs and stuff like That?
post #7 of 8
Based on your speakers, select the model which meets your feature requirements at the lowest price point as although you'll want to upgrade from the 1312, going to MultEQ XT will not likely add much.
post #8 of 8
thanks
