Hi, I was looking at getting a used VIsion HD to convert different inputs for an older Sony HDTV that only has a component input, no HDMI. It has a nice 1080i picture but I would like to connect some other inputs to it such as the VGA output from a laptop as well as a WD Media Player. In reading the manual for a Lumagen, it looks like it is capable of taking RGB and digital inputs and then converting them to a YPbPr output through the output DVI connector. My question is will the cables on monoprice work with the Vision HD?
For example, can I use this DVI to component cable to connect the Lumagen to my HDTV?
