someone gave me this tv without the door cover. I found that the tv will not start without the cover on. I am looking for a replacement cover. Does anyone know of a work around if I can not get a cover door? So, this is the plastic door that you have to unscrew a screw and remove to replace the lamp. I would think there would be a way to get around this without putting the door back on. If not, I will have to keep looking for a site that has the part.
AVS › AVS Forum › Display Devices › Rear Projection Units › Toshiba 56MX195 lamp replacement door cover
AVS Top Picks
