Start-up Bully Sound has launched its newest high-end home-audio component, the $7,900 BSC-60s Class A amplifier rated at 2x60-watt into 8 ohms.
The specs...
[Source]
n late 2011, the company launched its first product, the BSC-100m Class A 100-watt monaural amplifier at $14,750/pair. Its third product, to be released soon, will be the BSC-LL1 remote control line-level preamplifier at an expected $6,900 to $7,900.
The specs...
Bully’s latest product, the dual-mono BSC-60, is stable to 1 ohm, boosting output to 2x120 watts into 4 ohms, 2x240 watts into 2 ohms, and 2x480 watts into 1 ohm, both channels driven.
At 2x60 watts into 8 ohms, the amp runs at full Class A, but into 4 ohms, the amp run at Class A at up to about 2x80 watts but goes into Class AB mode after that.
The output stage for each channel consists of massive internally mounted heat sink towers to cool the six 230-volt, 17-amp 200-watt output devices. The BSC-60s also lets users reduce the Class A bias on the amplifier via a front-panel rotary switch to 50 percent, or about 30 watts, for a very low power eco mode.
The aluminum powder-coated chassis measures 16.5 by 9.75 by 18.25 inches, and it features custom-machined hardcoat anodized front panel, decorative inserts, and solid-brass machined gold-plated output binding posts.
Frequency response is said to be 20Hz to 20kHz +/- 0.25 dB with THD of less than 0.08 percent at 20Hz to 1kHz, at less than 0.7 percent at 10kHz, and less than 2 at 20kHz at 100-watt output into 8 ohms.
[Source]
