AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Vizio E601-A3 Owners Thread
Vizio E601-A3 Owners Thread - Page 50
post #1471 of 2576
Originally Posted by ListedGuru View Post
...Also what do you have your cable box set to ouput? When I watched my plasma I had it set to native so it swiched from 720p to 1080i depending on the source. With this Toshiba LED I have it set to a fixed 1080i...
By setting your cable box to a fixed 1080i, you are having the cable box do the conversion from 720p to 1080i before it gets to the TV. So, if your Toshiba TV looks good when the original material is 1080i, but not so good when the original material is 720p, it is probably because your cable box is not very good at the conversion. You should probably try letting your Toshiba TV do the conversion by setting your cable box back on "native", unless your Toshiba TV can only handle 1080i signals. The Vizio E601i-A3 can handle both 720p and 1080i, so, if your cable box is not very good at the conversion, I would leave it on "native" when testing the Vizio, as well.
post #1472 of 2576
Originally Posted by splinke View Post
The Vizio E601i-A3 TV and your Onkyo NR 509 both support something called Audio Return Channel (ARC), which allows audio to be carried from a TV back to a receiver over the same HDMI cable that delivers the video from the receiver to the TV.
I used to think I wanted a TV that supported ARC. Not any more I don't! Alas, using ARC with the E601-A3 requires HDMI CEC to be enabled. With HDMI CEC enabled, turning on the TV causes my AVR to be powered up and then the AVR's input to be switched away from the SAT/CBL input to the TV AUDIO input. This all occurs in slow motion as the TV slowly powers up. It's the switching of the AVR's input to TV AUDIO that drives me nuts. So I've now disabled HDMI CEC and run a TOSLINK cable from the TV to the AVR for the rare times when I may actually need TV AUDIO on my AVR. So much for ARC. So much for HDMI CEC. Pfft!
post #1473 of 2576
Is this set capable of the following?
Listen through the sets speakers, and when I power on my non ARC, HDMI connected OnkyoTX-SR607, the sets speakers mute and my surround comes on.
post #1474 of 2576
Just curious. Is there any difference for preference for 1080i or 1080p with this set? Or 480i/480p for the standard def stations?
post #1475 of 2576
Originally Posted by montecore View Post
Interesting....Vizio said this FW update is pushed out via serial numbers low to high......I have not seen it yet with 46 and I have not seen another 46 with it either. Now I see 50 and 51?
I have a 46 and I got mine on Saturday.
post #1476 of 2576
Just set everything on 1080p, the TV knows what to do.
post #1477 of 2576
So, I guess another required step is activating "HDMI CEC" on the TV:
1. Make sure your HDMI cable is "HDMI version 1.4-compliant".
2. Make sure one end of your HDMI cable is attached to the "HDMI 1" input on the Vizio E601i-A3 TV (that is the port that supports ARC).
3. Make sure the other end of your HDMI cable is attached to the HDMI output on the Onkyo NR 509 receiver (that is the port that supports ARC), and that the receiver is set to the "TV/CD" input.
4. On the Vizio TV, activate "HDMI CEC".
5. On your Onkyo receiver, set "HDMI Ctrl (RIHD)" to "On".
6. Turn off both the TV and the receiver, then turn them both back on.
If the automated input switching in that setup proves overly annoying, then go with the second option of just hooking up an optical audio (TOSLINK) cable between the TV and the receiver.
My receiver from 2004 does not support ARC (it doesn't even have HDMI), but I don't intend to replace something that works just fine. I have all of my devices hooked up to the TV and then only use the optical output from the TV to my receiver (the TV does the switching rather than the receiver in my setup). I use a Harmony remote to automate the process.
post #1478 of 2576
i have a harmony clone and love the thing. idk how i functioned before i got that remote.
post #1479 of 2576
I just noticed that my comcast cable box only will put out 1080i. It can do 720p and 480p but that's it. Is that common for a cable box to not have a 1080p option?
Update .... I see from a couple of different blogs that 1080i is as high as comcast goes.
post #1480 of 2576
h e l p meeeeeeee!
post #1481 of 2576
Can someone comment on the picture quality of this TV, watching over-the-air content?
I have seen this set at Walmart with terrible pixellation (don't know the source of the content). And I've also seen this set with very good image showing Blu-Ray content at Sams.
I know the colors can be tweaked to make it look good, but I wanted to know how good the picture was for non-cable, dvd content.
post #1482 of 2576
Has anyone compared the Vizio E601-A3 to the Panasonic TCL55E50 55-inch IPS LED TV?
I'm particularly interested in screen-glare and off-angle viewing comparisons.
Also, is the 60-inch TV significantly bigger than the 55-inch for viewing purposes, or is the difference hardly noticeable?
post #1483 of 2576
to date, there is no broadcast 1080p....everything is either 1080i or 720p....the only way to view 1080p is by blu ray or xbox/playstation games.....thats it
post #1484 of 2576
If anyone has a BJ's Wearhouse club near them they have the TV for $889.99 with shipping included in that price. Unfortunately I don't have one near but maybe this will help someone out. I'm thinking that Sam's and Costco might be discounting soon also? Or maybe a pricematch to BJ's somehow?
http://www.bjs.com/vizio-60-led-smart-hdtv-1080p-120hz-wi-fi.product.225489?dimId=&sc_cid=affil
-Guru
post #1485 of 2576
h e l p meeeeeeee!
I picked up a refurbished Harmony 650 for pretty reasonable price (maybe $30) and it works great.
Rick
post #1486 of 2576
Here we are one month after Christmas and the price is $889. How long till we reach the incredible Black Friday price on regular sale?
post #1487 of 2576
post #1488 of 2576
-Guru
I got my TV at BJ's for $100 more ($989). Some did say it might go down before the super bowl..but I had to buy early was a X-mas gift. Guess other stores will follow this lower price soon.
If anyone plans on buying one you should wait a week..BJ's price they say is till Feb 3rd at the $889.99 price, but if it goes lower at other stores do buy at Costco. BJ's gives you only 30 days to return the TV and Costco gives you a two year warranty free plus a very low discounted deal for extended three year warranty ( from what I read here)..way way better deal at Costco. Another hint if going in person to buy..some times they stock these TV boxes in the middle of the store not just the TV section...walk around and see if they do..this way you can read the serial numbers on the box ( its there-the sn# and model # sticker will be on one of the short sides of the box) and get the highest possible serial number you can find there (the first two digits in the serial number should be after a few letters..go by those two numbers for highest)
Still kicking myself for not going to Costco to buy my TV. Oh well.
Also just because it said its a online price..BJ's does sell it at that $889.99 price in store too...guess most others will too, to get rid of the over stock.
Edited by Internet2 - 1/22/13 at 4:48pm
post #1489 of 2576
I'm not sure if its a coincidence or not, but ever since my update, my youtube and Netflix app won't play without skipping badly. Any ideas?
post #1490 of 2576
Originally Posted by crawdad62 View Post
They must rolling out the firmware in ernest now. Seems like a lot of people got it yesterday including me. I turned DD back on on all my devices and it seems fine. Watched almost four hours of "Lawrence Of Arabia" and no problems at all. I think if my screen goes out I'll be really bummed. I've got my set really dialed in. Every time I watch it I'm amazed at the awesome picture it produces.
Make sure you make a note of all your settings to be prepared for Murphy's Law.
post #1491 of 2576
I have to agree, love this set. I just changed vid quality at Netflix and the clarity is absolutely the best I've ever seen. Incredible.
What did you change the vid quality too?
post #1492 of 2576
Few more questions before I make the leap:
How is the stand on this? I won't be wall mounting it so I want to make sure the stand is pretty good so the thing won't topple over. That works well. The connector has a triangular design which is the strongest constructional shape. Once setup if no one touches it then it should be fine. If there are rowdy kids around that is a different story. I have it mounted on the stand and it works great.
Also does anyone know the dimensions of the box? I picked this up in a 2004 Toyota Corolla with back seats down...I had to tie the trunk lid down....not a big deal.....the box is only 36" high. I need to make sure it will fit in my vehicle.
SO WHAT ARE YOU WAITING ON......GOOOOO AND GET THIS BEAST.....YOU WILL NOT BE DISAPPOINTED.
-Guru
post #1493 of 2576
1080p is the best however most HD channels are in 1080i.....most of the SD channels are 480i. The are also some 720p channels as well. When you force 480i to 60" by using the zoom on the remote the picture looks bad, grainy and choppy. I watch those in NORMAL mode.
Video games are the only area where people have been able to reach 1080p
post #1494 of 2576
Can you convert a 480i signal to 1080i or 1080P? If so how do you do that?
post #1495 of 2576
The PQ is AWESOME...when pulling in OTA HD in 1080i. Don't judge this set by is cover in a store. Take this set home in YOUR environment and tweak the settings. Or take my settings on page 43 to the store and ask them if you can tweak it.
post #1496 of 2576
Pay attention to the bevel that goes all the way around the TV. The Vizio has a thin bevel compared to the panasonic. Panny is NOT known for LED....they are known for Plasma. I have not noticed screen glare on the Vizio because it has a nice matte screen. I have not noticed huge issues with angle viewing either.
post #1497 of 2576
This is another great suggestion by Montecore, you never know if a firmware update will change your settings or bring it back to factory defaults.
Went to do it had paper and pen and just realized in the picture settings alone there are 'nine picture modes'..a lot of writing..so I just took pictures of everything on the Menu (picture,network,audio,help,system info...whatever..sure beats writing it all down. Saved the pictures to my PC named the folder and dated it..be something like a restore point. If I ever change settings for something I'll just delete the old picture and use new one and date it.
TY Montecore..glad you own the same TV as us.
Still taking pictures...even that alone takes time.
post #1498 of 2576
Glad you like the suggestion. It takes way too much time to tweak these settings to get them perfect for us now be pro-active and make sure you have a master copy in case Murphy shows up.
post #1499 of 2576
Has anyone had any freezing problems with the Netflix app on the TV? Had this happen twice in the last couple days. Usually the only way I can fix it is by turning the TV off. But when I do that it makes some auful popping noise. I don't know if the noise is coming through the speakers or if its the TV. But I was wondering if anyone had this problem.
post #1500 of 2576
My netflix and youtube app have been doing this the past few days and nothing fixes it..
