AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Vizio E601-A3 Owners Thread
Vizio E601-A3 Owners Thread - Page 25
post #721 of 3778
Originally Posted by dmako View Post
Question for those who have wall mounted their TVs. Do you use the 4 bolts that are pre-installed in the TV or did you use bolts that came with your mount?
I just get worried of using a bolt that is too long and hits circuitry in the TV.
Would like to know this too before I hang mine on the wall.
post #722 of 3778
I hung mine last night using the bolts that came with tv. The mount I bought came with 60mm long bolts when the vizio called for 10mm in the manual. It seemed strong, and I didn't want to have to use a bunch of spacers to make up the difference with longer bolts. I could be totally wrong though, just my opinion.
post #723 of 3778
I would also like to add I have experienced audio sync issues with my dish network service (hopper) and vizio soundbar...moving from hdmi 1 to hdmi 4 has seemed to help. I also factory reset the tv once. Not sure what helped more, or how long it will last.
Also I previously had optical audio ssues from tv out to soundbar which have subsided since reset.
post #724 of 3778
Originally Posted by tersec View Post
How do you get firmwate to update?
I just got tv today and put it online first thing
system info- version 1.0.2
If your TV is connected to the internet, turn it on for 5-10 minutes, then off for 5-10 minutes, & repeat until you turn it on and see a notice that the firmware has been updated. Vizio support said there was a counter that checks for new firmware every X-th time the TV is turned on, and I was able to get the firmware update within 30-40 minutes of trying this.
post #725 of 3778
Originally Posted by rickie View Post
Updates are pushed out by Vizio as long as you have it networked. It might happen over night. I haven't found any firmware downloads for TVs on the Vizio site.
Rick
Thanks it updated over night, so far loving it.
post #726 of 3778
the lenth of the mounting screws is going to depend on the thickness of the bracket being used....i used some that were longer then the ones that came with the tv, but thought that was a nice touch to pre install screws from the factory....the main thing to watch is that you dont use a screw that is too long as they could come into contact with the lcd....
the screws i used were m6 16mm....they were the perfect lenth for the brackets and washers i used....
post #727 of 3778
I didn't use the screws that came on the back of the TV. I used the ones that came with the mount I bought off of Amazon. The brand is "VideoSecu". $25 special.
I didn't use the included spacers either. I am not worried about the screws hitting the LCD, even though they were kind of long.
post #728 of 3778
Originally Posted by joedaddyecw View Post
So i just set my tv that i got from walmart for 688 and the first thing i notice when i turned it on where this rectangular line across the whole screen and a couple of lines that just wont disappear. it looks like its burned in. is anyone else experiencing this? does anyone know how to hard reset the tv?
That looks like BAD horizontal banding.
post #729 of 3778
Originally Posted by spanishcop View Post
Hello everyone,
I would like to ask for some assistance please. I just purchased this 60" Vizio and I'm not very technically inclined when it comes to cables and some of the latest LED/LCD TVs and latest options. I'm looking for 35ft cables that will provide good quality from my receiver to my TV which will be running through PVC piping in the wall from entertainment rack to wall mounted TV.
I was checking amazon site and didn't realize the amount of Hdmi cables out there with different gauges, some saying 1000 others 800, others with eithernet, ultra high speeds, and etc...
Any suggestions please for good quality cable 35ft in length.
Also, any suggestions for settings for best PQ on this set for television, movie and Xbox settings. I'm a noob when it comes to this stuff and not familiar with all the changes and updates to recent TVs and cables.
Thank you in advance.
Mike
Sent from my iPhone 5 using Tapatalk
Go to Monoprice and get HDMI 1.4 cables for less.
post #730 of 3778
Originally Posted by dhhuston View Post
For everyone having lip sync issues, I have discovered if you use the HDMI 1 (ARC) input there is a delay added to the video on the TV. This is if you are trying to connect a soundbar to the set in which case the video is delayed to help keep it in sync with the soundbar. If you use HDMI 2 the problem disappears.
Hope this helps alot of you with the lip sync issue. Mine was an immediate positive difference!
Anyone else have luck with this approach?
post #731 of 3778
not really, the lip sync issue is soo random...some channels, some of the time, changing channels resolves it for a short time, then it comes back....doesnt seem to happen on the local network broadcasts, just some random cable/sat channels....
post #732 of 3778
Anyone know what power cable type this is? To run it through the wall, I really need 5 more feet.
post #733 of 3778
Regular 3 prong, computer type power cord..................................
post #734 of 3778
I've had this TV for 4 days. This morning, while watching Netflix, it froze up then popped when I turned it off. Popped again when I turned it on. Everything appeared ok, then it froze again in the exact same spot on the same (Netflix) show. Popped again off and on. We have watched plenty of Netflix without issue up to this point. Seems to be fine now watching regular TV. Bought it at WalMart. Should I return it?
post #735 of 3778
60, 70 and 80 :-)
Photobucket
post #736 of 3778
No it is not. It is one of those 2 prong with a square and a circle end. Looks like this. I just cannot google square and circle end 2 prong to find a 10-15ft cord. Anyone know the exact name of this cord type?
post #737 of 3778
Originally Posted by Suzook View Post
60, 70 and 80 :-)
Photobucket
post #738 of 3778
I would be worried that the screws that came with the TV are too short. The threads in the TV are recessed & I found that the screws that my TV came with only threaded in a few turns without any brackets. With a thicker bracket you might only have one full turn of threads in use. My Monoprice mount came with 30mm long bolts and those thread in about 18mm before they touched anything. Instead of using spacers I bought some M6 x 16mm bolts at Ace Hardware and used those.
To tighten the bottom clips on the mount I bought this screwdriver set & they were more than long enough & a great deal at $5.
post #739 of 3778
I believe this is the cord you are looking for
http://www.stayonline.com/detail.aspx?id=6064
post #740 of 3778
Thanks! It seems this is the only place I can find longer iec320c7 cords. Has anyone used this website before?
post #741 of 3778
i also used 16mm mounting screws....to me the pre installed ones were too short for my brackets....my mounting kit came with a number of different lenth screws, i settled on the 16mm as i was able to thread them in all the way without hitting the end prior to using the bracket...the next lenth i tried hit the end before the screw was all the way in, so i went with 16mm....anything longer will require some spacers
post #742 of 3778
i went on ebay and typed in tv power cord, and all kinds of this cord came up in different lenths.....
post #743 of 3778
I can always have an optical out cable from the TV to the soundbar, but will that be in Dolby Digital Surround Sound? Any recommendations you could provide would be so very appreciated!
I have an optical cable from the TV to my surround system, and as long as the program supports DDSS it comes through properly! I think this is the best setup. This way my Xbox, bluray player, wii, cable box, and any TV apps all go through my sound system, with only one cable hooked up.
If you want to just use the TV speakers for early/late watching, power off the soundbar and turn the TV up.
post #744 of 3778
Hey guys, I was reading a thread on slickdeals and someone stated that this TV wont do 1080p past 24 Hz. Can anyone verify that this is indeed the case? Seems crazy that a modern TV cant do 1080p at 30 or even 60 Hz. I tried searching but didn't turn up anything about it.
post #745 of 3778
Yea I agree, but not many online, nearly none on ebay that are polarized iec320c7 larger than 6ft.
You could buy something from ebay, but the most common iec320c7 seems to be non-polarized. I'd rather get the same exact cable, but longer.
post #746 of 3778
My HTPC is outputting 1080p60 & the Vizio is handling it just fine.
post #747 of 3778
I'm not getting Dolby 5.1 from Sons of Anarchy on Netflix, but I am getting it from Breaking Bad on Netflix. Both titles say they are 5.1. Using Toslink to receiver. Is something set up wrong? Glitch in the TV? Or is SOA possibly mislabeled?
post #748 of 3778
I am going to be wall mounting the 60inch, but I want it to be able to swivel also. Anyone bought a good, cheap swivel mount for these things? I dont just want it to be able to tile up and down.
post #749 of 3778
why do you care if its polarized or not....i would rather it not be....but at the end of the day it doesnt really matter
post #750 of 3778
60, 70 and 80 :-)
All you need it the 90" one to complete the set.
