AVS › AVS Forum › Video Components › Home Theater Computers › G550 stuttering on 2D bluray
post #1 of 26
Hi,
I've recently built me a budget system with a purpose to play everything except 3D:
B75M: ASRock B75M, B75, DualDDR3-1600, SATA3, SATA2, HDMI, GBLAN, mATX
BX80623G550: Intel Celeron G550, 2.60GHz, 2MB, LGA1155, 32nm, BOX
AD3U1333C4G9-S: A-DATA DDR3-1333 4G 256*8 CL9 S-TRAY
SSD Crucial M4 64 GB
No discrete video card yet. Running win7 x64 + xbmc. All the latest drivers installed. No DXVA turned on.
Majority of 1080p files play fine (~30% CPU usage), however, i've run into some files, which do not play smoothly - intense action scenes stutter a bit, frames are being dropped. CPU usage on these files average at ~50% and spike up to 70-80%.
Here are the details of files, which do not play smoothly (no difference if it's streamed through wired 100 mbps network or USB hdd):
Format : Matroska
Format version : Version 1
File size : 5.90 MiB
Duration : 11s 394ms
Overall bit rate : 4 345 Kbps
Encoded date : UTC 2008-05-23 08:52:00
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : libebml-0.7.5 & libmatroska-0.7.7
Language : fin
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 3 810 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Original frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 623 KiB (10%)
Default : Yes
Forced : No
OR
Format : BDAV
Format/Info : Blu-ray Video
File size : 259 MiB
Duration : 1mn 2s
Overall bit rate mode : Variable
Overall bit rate : 34.7 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 1mn 2s
Bit rate mode : Variable
Bit rate : 25.7 Mbps
Maximum bit rate : 32.0 Mbps
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.517
Stream size : 192 MiB (74%)
Audio #1
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Muxing mode : Stream extension
Codec ID : 134
Duration : 1mn 2s
Bit rate : 4 888 Kbps / 1 510 Kbps
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Delay relative to video : -122ms
Language : English
Do you think such files could be too demanding for G550 iGPU? If not, where could I start looking for problems? Maybe I should think about discrete video?
Thanks for your thoughts.
post #2 of 26
Turn on DXVA. Why do you have it off? That is why its there. That fix it?
post #3 of 26
DXVA doesn't work with XBMC when using the Intel iGPU. Its an XBMC issue.
I would start by making sure you have all the drivers installed and that you are using the most recent drivers and not just the ones from the CD that came with your motherboard.
post #4 of 26
I've done a clean install of windows, used the newest drivers from MB website, but still, stuttering is exactly the same.
I've tried to turn on DXVA2 - there is no stutter then, cpu usage is ~10% only.
What are the reasons why DXVA2 can not be used with intel iGPU? Didn't notice any issues yet (maybe had to test more)..
post #5 of 26
Macroblocking.
You haven't described at all your audio setup. Incorrect bitstreaming can also cause stuttering. Tell us what you are bitstreaming and to what devices and how they are all hooked up.
post #6 of 26
Originally Posted by assassin View Post
Macroblocking.
yeah, you're right, tried another file with dxva on and severe macroblocking was present..
I have my htpc hooked up to my panasonic g30 plasma by hdmi. no av receiver for now. i've made some screenshots showing my setup and few files i get stutter on. here's the link: http://imageshack.us/g/1/9809301/
any further ideas? thx
post #7 of 26
What audio formats are you trying to bitstream?
post #8 of 26
Where could I find such information?
As I said, I've connected my htpc directly to TV, so I'm not bitstreaming audio to AVR. Information about the files I'm trying to play is indicated on my first post.
post #9 of 26
I believe you are using my guides which has a relatively detailed explanation on bitstreaming and when not to use it. In your case there is no way that your HDTV is able to accept or decode DTS-HD (or plain DTS) which if you have bitstreaming enabled you are sending to your HDTV which is likely causing your stuttering issues. Likewise with that other file.
post #10 of 26
yes, i've used your guides and followed xbmc guide option 1 for installing (no hd audio capable receiver). Also, as my above posted screenshots show, under audio output i've chosen audio output to be analog, so as far as I understand bitstreaming is disabled, right?
post #11 of 26
Why have you chosen analog if you are connected via HDMI?
post #12 of 26
this was set by default. just tested with hdmi output - the result was the same, stuttered on high bitrate scenes.
post #13 of 26
Does anyone have any other suggestions I could try?
Or maybe >40 mbps video stream is simply too demanding for this CPU to handle? can any other Intel Celeron G5XX owner confirm if they really do not have issues with all 1080p 24p files playback? thx.
post #14 of 26
Have you tried to decode with Quicksync? On my G540 I have no problems with standard 1080p x264 10MB/s rips, played back at 50Hz. Can you post a 5min clip so I can test?
post #15 of 26
No, I have not tried with Quicksync. Is it possible to use that with XBMC ?
I'll post a file for you to test on weekend.
post #16 of 26
I have 4 HTPC's all using G540's , I use plex and haven't had any issues with 720p, I dont have many 1080p, post up a sample, i'll test it out.
post #17 of 26
I've never had personal experience with a g5XX, but I was planning a build that would include one. This is interesting to me, but I don't know enough about the video file details you posted to understand what the source for these files would be
What is a variable frame rate, as shown in the first clip? Is this typical for rips or pvr stuff? Or did this come from a personal video camera with some kind of frame rate optimizer?
post #18 of 26
Are you 100% certain you have all drivers installed?
post #19 of 26
Based on that comment it would seem safe to assume, and I thought there are only 2 necessary intel drivers (chipset and graphics) could be wrong haven't done the setup in a while
It's all pretty difficult to troubleshoot without further feedback biggrin.gif but I still don't know where a variable frame rate source would be from . . . no matter how much you learn there's always something else
post #20 of 26
I'm pretty confident I've installed all the drivers - I even did a fresh windows install. I've downloaded drivers from asrock site also updated intel drivers on their website.
Anyway, if some of you guys with g5xx would test a sample I've made and would get a stutter free playback, then I would be looking for further faults on my system. File is ~2 mins in length, I get stuttering and frame drop from ~1:30 to ~1:50. Please test without hardware acceleration, just with software rendering. Here is the file:
http://www38.zippyshare.com/v/14176325/file.html
mirror:
http://www.sendspace.com/file/vqri1i
Dark_Slayer: video file details are indicated in first post of this topic.
post #21 of 26
So... Are there no G5x0 owners up for a test?
post #22 of 26
i just finished my G550 build. i'll try out a couple of blu ray isos in xbmcbuntu.
post #23 of 26
ill try it later
post #24 of 26
i've played quite a lot of content since my last post. I'd say ~95% of all 1080p files were running smooth. These remaining ~5% did stutter in a few scenes only. anyway, i'm not planning to add discrete card yet..
post #25 of 26
Download Error > Upload New File
Sorry, the file you requested is not available.
This file has been deleted and it cannot be restored. Please contact the sender and ask them to upload the file again.
post #26 of 26
sorry for the huge delay, and i hope i am not needlessly bumping an old thread, but i thought this information might be useful.
as someone else mentioned, dxva, xbmc, and the G550 don't get along well for some reason. everything i play is choppy...720p, 1080p, etc....
however, playing these files off arcsoft totalmedia theater 5 is buttery smooth. everything works for me, including HD audio, smooth video playback w/o any hiccups, etc...
i think we'll just have to wait for xbmc to fix this up.
