AVS › AVS Forum › Display Devices › Screens › screen question
screen question
post #1 of 6
So I'm going to be installing a projector in my basement home theater. I basically have perfect light control. there is 1 small window that I have completely covered with a curtain.
I plan on getting a epson 3010 and was curious if this screen would work well with it?
http://www.amazon.com/Elite-Screens-M100XWH-Manual-Projection/dp/B000B60LVG/ref=pd_cp_e_1
I'm not sure what size I will be getting yet, cause i still need to measure what the biggest I can get is. The room is WAY longer then it is wide, so I can put the projector pretty much anywhere I need to.
post #2 of 6
bump.
post #3 of 6
It should work fine. Get the largest size you can fit comfortably in your room. Just remember that the 3010 doesn't have lens shift so it needs to be mounted so that the lens is centered with the top/middle or bottom/middle of the screen depending on whether it's ceiling mounted or on a table. Love my 3010!
Ed
post #4 of 6
It will be ceiling mounted.
Is there another projector in that price range with lens shift?
post #5 of 6
B-stock JVC HD250 or B-stock JVC RS40.
post #6 of 6
What does b stock mean?
  Back to Forum: Screens
