AVS › AVS Forum › Display Devices › Display Calibration › Why correct gamma makes my display very dim?
post #1 of 5
I was trying to calibrate my plasma (Samsung) using radiance mini 3d and CP. It turned out that "before" gamma was very wrong going from ~1.2 at 90% to ~1.8 at 10%. Using either manual controls or CP autocalibration I could make gamma curve much flatter and close to 2.2. The problem is that it makes picture much dimmer! I know now that it is supposed to get dimmer when I rise gamma at right end from 1.2 to 2.2. So, technically it is much more correct after calibration but I just cannot stand that dim picture! Is this a problem with my display, my eyes, my brain?? Anything I can do to get correct gamma without dimming the picture?
post #2 of 5
can you increase peak white by turning up contrast? or is it already as high as it can go without clipping/discoloration?
post #3 of 5
max
You need to ask this in the Chromapure thread.
Sounds vaguely familiar but not sure if I read it there on the Calman thread.
post #4 of 5
If your peak output at 100% is near 120 cd/m2 and the gamma is in the 2.2-2.3 range, then this is what a calibrated display looks like. If you had gotten used to a gamma of 1.2, then this may look dim to you.
post #5 of 5
It turned out that the problem was me using field model to calibrate plasma. It was reading gamma incorrectly and was trying to fix it by reducing brightness. Once I switch to window, gamma reading was much more reasonable and brightness was not change after calibration.
