AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Can amps be mounted sideways?
post #1 of 4
Hello,
I have an Adcom GFA-535 (on order). Is there any issue with moutning it on its side?
I thinking about strapping it to a desk to give me easy access to it and improve cabling options.
J
post #2 of 4
Since it's convection cooled, with holes in the "top", it may need to have some fans added to keep it cool.
post #3 of 4
Do you trust the mounting of heavy transformers and other components to hang vertically permanently?
post #4 of 4
I am sure its not ideal, but I had no choice in the matter, I have had a Denon POAT10 THX power amp on its side, it was 8 years old when I got it on EBAY, and it has been working OK on its side for 4 years since.
Edited by kdp99 - 10/13/12 at 2:53am
