I have been running a Windows based HTPC for years. For various reasons I want to add a second HTPC that is Linux based to run XBMC. My intent is MCE for the PVR and XBMC/Linux for everything else. All IR receivers I have found are RC6 so the drivers recognize them as an MCE receiver and are setup for the Windows MCE IR codes. Two RC6 IR receivers would lead to both HTPCs accepting the same IR codes for the same actions. This will cause me troubles. Are there alternatives to RC6 receivers, or other HTPC like devices that can be emulated that are not MCE?
Any suggestions are appreciated.
Cheers!
Apologies for the cross post. I wasn't sure where best to stick this.
http://www.avsforum.com/t/1433854/ir-suggestions-for-two-htpcs-in-a-single-room-one-xbmc-linux-one-mce-windows
Edited by scottlindner - 10/14/12 at 6:48am
Cheers!
