Originally Posted by jnabq
DSL has gotten alot better, depending on the area you live in. My centurylink package is currently giving me, 12123Kbps downstream, normally the higher "upstream" rates are lower, vs cable, unless you pay more. That's over 2x the downstream rate my cable had, for less money, on the 5 yr pricelock package.
Just found a new test with different speed rates..Tested my speed:
Down load @ 29.5Mbps and uploaded @9.14 Mbps
Now I can compare at the same rates...
OK I think I am getting this, then your speed was 12.1Mbps and you say that is twice as fast as your old cable?? Sad.
Looks like I need 40Mbps DSL to match/beat my current Cable rates.
Rich
Edited by racprops - 1/19/13 at 3:58am
