Originally Posted by SoloForce
OK. In my opinion. 1 foot sounds like a lot of work. It might hide the projector nicely. But being so close to a duct, will it bring more heat to the unit.
You can use the zoom function. You'll have space.
I would get your screen placement. And projector placement. Hold it up. Experiment with different positions before you mess with the duct. You may
find you don't have to touch the duct at all. I positioned my set up multiple times. Did my calculations. Drilled my wholes. If I made a mistake. Make new holes.
All before painting the ceiling etc. I hope I understand what your trying to do. But those would be my concerns in my opinion. Good luck!
iMIKE THEATRE
iMIKE THEATRE
No, you got it pretty good. The box that houses is overly large where my projector will be (up the line, there are more ducts necessitating a bigger box). There's plenty room in the duct box to fit the projector without moving the duct, I just need to build an enclosure. It would do two things, 'hide' the projector for a cleaner look, and move it back 16" to extend the throw distance.
