AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Official Epson Home Cinema 3020 Thread
Official Epson Home Cinema 3020 Thread - Page 32
post #931 of 1055
MY PHONE HAS A BROKEN KEYBOARD. .
post #932 of 1055
Originally Posted by whitecamaross View Post
CAN YOU POST THE CALIBRATION SETTINGS YOURE USING? ? I HAVE ONLY FOUND THE ONE FROM PROJECTOR REVIEWS. . .
If you use the SEARCH THIS THREAD at the top of the page. And type Calibration.
You will eventually see every post on calibration in this thread of the 3020.
This would come up in the list.
http://www.avsforum.com/t/1433899/official-epson-home-cinema-3020-thread/870#post_23720749
This were just mine using, both the DISNEY WOW Disc and My Own 3D Calibration Disc.
iMIKE THEATRE
post #933 of 1055
All my calibration settings are being done directly thought the iscan. I have left the projector in cinema mode. Didn't change anything on the epson. It was a bit off but not by much.
Sent from my iPad using Tapatalk HD
post #934 of 1055
Hi All,
I just got a great deal on this projector today ($850 open box). They gave me a 7 day return policy, so I want to make sure my unit is great before I decide to keep it. Can you guys help? A few questions:
1 - When I flip it over, I hear something loose inside the projector. Is this normal?
2 - If I project a white image, and look at the lens from above, there appears to be some scratches inside the lenses. Weird. The image seems fine.
3 - Can you guys try this focus / convergence test? http://www.aaarpinball.com/Miscellaneous/p1080.htm
After trying it, and doing the focus on green, I notice that both green and red look sharp, but blue looks "dim" with the black background. If I switch to a white background, blue looks better, but not as sharp as red / green. Can you have a look and see if you notice the same behavior?
Also, out of the box, looks like I have a lot of convergence issues, but I was able to align it well with the tool provided by Epson.
post #935 of 1055
IMG_0285.jpg 747k .jpg file
IMG_0287.jpg 554k .jpg file
IMG_0289.jpg 665k .jpg file
Here is what I'm talking about, can someone test and let me know if looks the same?
post #936 of 1055
WHERE DID YOU GET THOSE PATTERNS?
post #937 of 1055
Right here: http://www.aaarpinball.com/Miscellaneous/p1080.htm
post #938 of 1055
WHERE DID YOU GET YOUR PROJECTOR FROM?
post #939 of 1055
Did you get it from an authorized seller.
post #940 of 1055
I believe so. It was a warehouse sale from ncix.com. They said I get the full 2 year warranty, plus a 7 day return. But I just want to make sure it's all good, as I'd prefer to keep it... smile.gif
post #941 of 1055
If you're positive it's an authorized dealer, I'd keep it regardless of whether it has issues or not. Epson will swap it out for you anyhow so don't worry about it..
post #942 of 1055
Umm, I'd prefer not exchange a "almost new" open box from a refurb, but hopefully someone with this proj can do the test above and compare the results.
post #943 of 1055
EPSON DOESNT ALWAYS SEND REFURBISHED UNITS. . I BOUGHT ONE REFURBISHED ONE FROM THEM AND IT WAS ACTUALLY A NEW UNIT.
post #944 of 1055
Hey all, got a refurbished 3020 coming in directly from Epson... I'm pretty excited! I need some help picking up a mount, so opinions are needed.
I've got a triangular shaped room as far as viewing from the screen and I want to wall mount the projector. Given the dimensions of my room, the wall which will mount the projector will be at a 45 degree angle from the screen (as opposed to being on a parallel back wall) but still dead center.
I've seen people mention this peerless mount and it looks like it should work: http://www.amazon.com/Projector-Ceiling-12-8IN-17-3IN-Adjustable-Extension/dp/B00155RH2I/ref=sr_1_5?s=electronics&ie=UTF8&qid=1385430680&sr=1-5&keywords=projector+wall+mount
Any other options in this price range? (unless this one won't work of course, in case I'll take what I can get)
Thanks ahead of time for any replies.
post #945 of 1055
Thanks, I just spoke with them today and they said they will let me use the 2 year warranty if there is any issues... smile.gif
If anyone that have this projector can have a look at my test above and provide some insight, I'd really appreciate it!
post #946 of 1055
HI GUYS I JUST BOUGHT A REFURBISHED 3020 AND NO ISSUES. . PERFECT ALIGNMENT, COLORS, NO NOISES, GREAT FOCUS AND ILL GO OUT ON A LIMB AND SAY THIS UNIT LOOKS BETTER TO ME THAN MY 8700UB. . EVERYTHING POPS, COLORS ARE BEAUTIFUL AND NOT DULL LIKE THE 8700UB.
QUESTION FOR U, HOW MANY OF YOU GUYS USE ONLY TWO MOUNTING HOLES INSTEAD OF AlL FOUR? THE MOUNT I BIUGHT ONLY ALLOWS FOR THREE HOLES BUT IT WONT REALLY REACH ALL 3 BECAUSE THE PROJECTOR IS TOO BIG. . CAN I ONLY JUST USE THE TWO FRONT ONES? IT FEELS. PRETTY STURDY. . BUT JUST WANT TO MAKE SURE? ?
Where did you get the refurbished piece from ?
post #947 of 1055
I JUST RAN THEM AND I SEE THE BLUE ABOUT THE SAME AS YOU. I WOULD SAY YOU HAVE A GOOD UNIT AS LONG AS YOUR PICTURE IS FINE. NO PEOJECTOR IS PERFECT AND I PERSONALLY DONT SEE ANY ALIGNMENT ISSUES WITH THE EPSON PATTERN.
YOUR UNIT IS FINE. NOW START LOOKING FOR AN OPPO BLURAY AND CALL IT A DAY.
post #948 of 1055
Awesome, thanks! :-)
post #949 of 1055
There is any good deal on this projector ??
post #950 of 1055
Hi guys, newbie here, just picked up a 3020 for 1249 from best buy, ATM just quickly set it up shooting on a wall until I can decide what screen I want to get,
So far great except for I've notice some scratches on the lens? It's hard to tell if there inside it outside tried to lightly wipe it but seems there is more to it
I've also notice a dark line about a 1" thick running vertical on the screen, it Dosent seem like the wall would cause this
Any ideas would be greatly appreciated, prolly give epson a call tomorrow
Cheers
post #951 of 1055
Cheers
If there's a scratch on the inside of the lens...It's not suppose to be there. It might actually end up distorting a part of your picture you'd barely notice.
I project a BLACK image in this case. Let your eyes adjust to the screen. Look very carefully. Do you see any colours? Did you see a SPOT, or a BLOTCH.
I might return it.
But THE 1" line. That's a return for sure. Something is wrong. And it could get worse.
Sorry if it sounds like bad news. But the hassle you will have. Will pay off in the long run. I hope.
I love this unit. After many, many returns. The last unit I have is PERFECT. almost 1 year. no issues.
iMIKE THEATRE
post #952 of 1055
Ya lol head back to best buy, they had a really good knowledgable guy that does there theatre installs and mainly deals with projectors, can't see it being much of a hassle other than re packing all the goodies that I opened like it was Xmas
post #953 of 1055
how do i access the service menu on this unit and how do i go about doing the alignment from the service menu?
post #954 of 1055
Last night I was listening to music then switched over to a bluray.i noticed I was getting picture but no sound out of my speakers.
A few minutes later the projector shuts off and the lamp and temperature lights are flashing red.The manual says to unplug and call epson. However, I waited and plugged the unit back and was able to watch two movies without an issue.
This morning I called epson to report it and they said this can happen but if it happens again in pretty short time then they'll swap it.he made it sound like it can happen on some units but it shouldn't happen frequently.if it happens say once in a blue moon like every six months that it's okay but that most people have that happen to them once and then never again. Can anyone give me their personal experience with this issue.?
post #955 of 1055
I have received several PM's about the "hidden menu" in the 3020. You guys must have missed my post about how to access ACTUAL usage data a few pages back:
http://www.avsforum.com/t/1433899/official-epson-home-cinema-3020-thread/810#post_23634701
For LCD alignment see this:
http://www.avsforum.com/t/1366241/my-epson-3010-projector-just-arrived/1260#post_21893195
It's the same for both the 3010 and 3020.
As always, proceed at your own risk/with caution. Good luck.
post #956 of 1055
I have an issue I've noticed a few times - occasionally, the picture will go to what I call a 'slow motion' look; the audio is still clear, but the motion on the screen has a kind of start/stop look to it. If I pause for a few seconds, then play, it usually returns to normal. I've had this happen quite a bit using a HDD DVR, occasionally watching Netflix over my DVD player, and very seldom watching DVD's.
I have my 3020 set up with a 30' HDMI running through the ceiling. I've wondered if 'pushing' the signal over that distance is a factor. Also, it seems worse proportionate to the resolution. ie, the DVR outputs 720p, it happens quite a bit with that; a regular DVD doesn't do it as often, and I don't think I've noticed it with a BluRay.
Any ideas?
post #957 of 1055
Ok so I still don't comprehend how to align it ..I did everything but the yellow square is not really super sharp to really align it perfect. I mean, I can try to center both colors to blend as perfect as as possible with the yellow square but it's not like the square is super super sharp like an led tv would display it with perfect focus .
post #958 of 1055
Any ideas?
If you can, move one of those sources closer and connect it directly to the pj with a short hdmi. This will help you begin to narrow down the problem.
post #959 of 1055
I just picked up a 3020, and although it is a huge improvement over my a Epson 550, the picture just seems soft. Now after watching a 53 " LCD and seeing how sharp it is I am concerned about the image on my projector. Should I expect it to be as sharp (or almost) as sharp as my 53"?
post #960 of 1055
I don't yet have a projector although your question reminds me or when I first got my first lcd tv. I could have sworn something was wrong with it as the picture just seemed so fake almost to sharp of definition, now I'm used to it so it seems great. I wonder if your just used to the way the lcd looks so therefor the projector seems soft. It seems like even the theaters image is softer than my TV.
