I am assuming that what I see on the DIY channel lately to make a "hidden television" in a mirror is just a two way mirror. Is that right. I am planning to make the screen into the master dresser mirror. Can anyone tell me.:
1. If indeed a two way mirror is what they use for this?
2. How it effects the actual viewing, both plasma and led considered?
3. Shortcommings - heat issues, etc.. Does it work better in Dark room ( I do suspect)?
4. Specifics to install. Does there need to be small space, flush, etc?
5. What about going to the trouble to disassemble the TV (Plasma example). My LG 60" plasma states "Protective Skin Glass". Can I remove that and replace with two way mirror? Would this make the best picture with this application?
