AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Offical Pioneer VSX-822k owners thread
post #1 of 5
I noticed that there wasn't a thread for this receiver. Just bought this receiver last week and been figuring it out slowly. I previously had a onkyo sr-606 until the hdmi blew and they wanted to much to repair over half of what I paid for it. Went to bestbuy and found this receiver and it looked like the best out of their options. Im powering two monitor 50s, a CS1, two monitor 40s, and a ESW-V10. I ran the configoration 5 times and it set the speakers to 100 HZ and the speakers to large. in the threads Ive been reading it says to set speakers to small and crossover to 80hz. Whats the best way to config the audio setting to get the best sound on paper. Let me know I'd like to get the best out of my home theater system.
Thanks Josh
post #2 of 5
Picked up from Amazon for $230, $150 discount since new models released.
Using 4 Bergtek HDMI 1.4 cables to connect sources and TV. Setup was pretty easy. MCACC works and does improve sound although there is no adjustment after other than bass/treble controls.
Front speakers are vintage Hafler 300 towers and rears are JBL HLS410. No center or sub. Return to Forever bluray with dts hd sound was very naturalwithout the hyped up subwoofer boom from my old yamaha setup. Cheap subs just don't sound natural to me. I won't get room rattling explosions but that's ok. The Haflers go down to about 70hz strong, then fade out at 35hz testing with signal generator test.
The one thing I do not like is that I can't set a surround mode for each input. So, if Dolby Digital or dts is present those are auto selected, that is ok. Stereo soundtracks for all inputs have to be stereo or decoded as pro logic or dts neo6. My old Yamaha would remember what surround mode I selected for each input. The DTS neo6 seems to sound the best compared to Dolby PLII.
Listening to flac files off my nas. Sounds pretty good although not as nice as my vintage h/k amps in the mancave stereo. Dts neo6 music seems to sound best. The mcacc eq really makes it better initially, have to do more pure direct listening. Sound retriever adds some pop to the music and doesnt seem obtrusive or fatiging to listen too on some jazz music. I need to try my h/k pm655 downstairs for comparison.
So far it is fulfilling my needs for the living room HT setup. Not as easy to use as my old Yamaha and I wish I could tweak the MCACC EQ settings. Sometime I'll use some test tones and my spectrum analyzer on my phone to see what MCACC is doing as far as EQ.
I do like the Android remote app for my phone, works pretty good. Easier to navigate internet radio stations with my phone over the remote control.
post #3 of 5
Just bought and set up this receiver and I have a very stupid question. In the auto surround mode, it seems like most of the time, the receiver is only pumping audio through my front surround speakers with nothing coming through the center channel. Is there a way to adjust this but still stay in auto surround mode?
post #4 of 5
it depends on the source. If you have a two channel signal coming in then all the content will go to the left and right front speakers. Now if you have a Dolby Digital 5.1 signal the the center speaker should get the majority of the vocals and dialogue.
There is no reason to leave your setting on Auto if you prefer another sound mode. Just change it to what you want.
What devices do you have and how are they connected to your receiver?
post #5 of 5
I have a Tivo Premier, Panasonic Blu-ray and X-box 360 all connected through HDMI. There is some content that comes through the Tivo that is auto detected as 5.1 but I would say the majority of it seems to be detected as stereo, even channels like HBO which I know from previous receivers is 5.1.
