AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Do you turn off your subwoofer when not using it?
Do you turn off your subwoofer when not using it? - Page 2
post #31 of 55
never.. sounds silly to worry about the ridiculously minimal wattage a subwoofer uses when not in use.
post #32 of 55
Originally Posted by d_m1010 View Post
I've been unplugging all my equipment when not in use and saving around $100 per month. I have a lot of gear in my HT room.
+1
post #33 of 55
I linked to this thread from the main AVSforum home page. Where did that awesome subwoofer picture come from?
post #34 of 55
EP4000 is remotely powered off after every use
post #35 of 55
ha, i went to the homepage to check out what you were talking about. that is indeed an awesome looking subwoofer.
post #36 of 55
Auto for me. I use to turn it off but the power comsumption is so small, just an LED light, it's not worth the bother. If it didn't have the Auto function I would definitly turn it off though.
post #37 of 55
By turning off your HT equipment your saving $100 a month? LOL o my god you would need a warehouse full of equipment to generate enough power on STANDBY to be burning through $100 in standby HT equipment bills!!!! Seriously think about it! cool.gif
post #38 of 55
If someone has a lot of pro stuff( esp amps) that don't have stand-by....it can add up very quickly. $100/month still seems unusually high but definitely not impossible.
Tom V.
post #39 of 55
Hi Tom
What do you think of using Smart Strips for AV? The TV could go into the "trigger" outlet, and the rest of the stuff can be plugged into the outlets that are off (until the TV is turned on). It might take a heavier duty Smart Strip than the 15 amp model that I use. One would have to look carefully for the least expensive Smart Strip that handles more than 15 amps. There are some Smart Strips that cost hundreds. I think you could find one that is rated for more than 15 amps but is much less than that.
It is also conceivable that you could manage with the 15 amp model which usually is enough to run an 1,800 watt appliance, like a hair dryer.
post #40 of 55
I leave my subwoofers (Fathom F113's) on. They don't draw enough electricity for me to be concerned about. I leave the rest of my equipment processor and two amplifiers in standby mode when not in use as they are specifically designed to be left on continously. I know in the past when I have had a component fails it's upon initial power up.rolleyes.gif
post #41 of 55
I called JL on this question a while back and they made the strong recommendation not to turn off (and particularly unplug) the subs to avoid the large power inrush that occurs when reconnecting the sub to the power line. They are of the definite opinion that the current inrush has the potential to damage the device.
post #42 of 55
With all due respect, didn't they used to say the same thing about computers? That is, leave them on all the time. Some people I know choose to leave their computers on all the time but you will upgrade computers before there are any issues with turning them off and on even multiple times per day.
post #43 of 55
You upgrade a computer due to new features or addition of memory don't you? Not because they had a power supply failure.
post #44 of 55
Originally Posted by BeeMan458 View Post
The next ecological upgrade will be a tankless water heater...
But, but, but...what will you do when the zombie apocalypse comes and you don't have a large reservoir of water to live off?
post #45 of 55
Tom V.
Still not going to happen if they are just in standby. I've got 28,000 watts of power for my HT and even if I leave all my stuff on (which I do quite often) my bills are under $150 per month and about 180-200 if winter is super cold. Thats total bills for the entire house and garage. I don't even notice a difference in the bill with everything off in the HT.
The only possible way that guy could save even close to that is if his stuff was all class A gear and he had 20 of them, as even in standby they still use lots of power.
post #46 of 55
I'd say it all depends on the gear. What's the cost of 1w for a year? Something like a buck? I have stuff in my house that will pull 50-100w at idle. So that is one piece of gear....costing $50-100 a year. Divide by 12...$4 to $8 a month. For one component.
Even if you subtract usage time(say 2 hours a day on avg?) I can't say with certainty that the $100/month claim is false. Seems possible to me?
Tom V.
post #47 of 55
Hi Tom
That should work fine. Based only on my personal experiences I really haven't noticed a trend one way or the other regarding failure rates in electronics based on how I've treated them (leaving on most/all time versus turning off every night). Maybe I've just been lucky.
Tom V.
post #48 of 55
apprantly you haven't seen a photo of his room. i would describe it as overkill to say the least.biggrin.gif
also he lives in Canada..possible rate/usage differences as well compared to usa.
post #49 of 55
Tom V.
You guys in the states pay more than most guys in Canada for power. You may have "stuff" in you house that pulls watts but is all that stuff in you HT? This is just something I found in about 2 seconds of searching http://www.hardwaresecrets.com/article/How-Much-Power-Do-Electronic-Equipment-Consume-When-in-Standby-Mode/519/6
Even huge power amps like my 4 x fp14000 clones use less than 35 watts at idle. $100 is not gonna happen I'm afraid. My 7 x 500 D-sonci amp uses a few watts in standby, my RMX 5050 and ep4000's use around 30-40 watts sitting in idle and thats not even in standby.
post #50 of 55
Anything is possible but let's remember, the OP asked about ONE subwoofer and the cost savings. Not the guy in your town who has jammed an entire IMAX theater into his basement and had to have his electric panel upgraded to support his drain of the grid. I don't see anything in the manaul for that particuar sub that says anything about a standby mode, so if it's on all the time, yeah, maybe a couple of bucks a month. If it has some undocumented standyby mode, a buck a year. If it has no standby mode though, I'd turn it off. Of course, I'm in AZ where I think about my two 5 ton A/C units cooling electrical crap that's left on all the time more than the power the unit uses.
Edited by emesnik - 10/20/12 at 2:02pm
post #51 of 55
If he has a rack or two full of pro amps it would be pretty easy to save $50-100 monthly. Many of them don't even have "stand by" just a rated "idle" draw. And you can be looking at 75-100w at "idle" from moderately powerful amps(1000-1500w)----particularly if they are more than a few years old. If you have 5-6 of those you're at $40-$50 a month right there. I haven't seen pictures of the system in question but I have seen plenty of pictures with 10+ pro amps in larger HTs. $100/month seems not only possible but quite likely in these rare instances.
Tom V.
post #52 of 55
Even in "Standby" most subs will pull around 15w unless the amplifier used is a newer "green" type. Then you are looking at 1 or 2w iirc.
So figure $15 a year in most cases, $1 or $2 a year with a "green" amp.
Tom V.
post #53 of 55
My subwoofer amplifier and crossover EQ unit goes into standby when not is use for about 20 minutes. I can hear the relay click in when the units are activated.
My 55" LCD television is set to turn off if the remote control is not used for 2 hours, and that is a money saver.
Interesting information on standby use of electricity in electronics. Cable boxes and DVD's are always on. Look at the note about those plug in low voltage wall packs.
http://www.aceee.org/consumer/home-electronics
post #54 of 55
Lately I've just been unplugging my subwoofer (SVS PB 13 Ultra) & AVR (Denon 5308CI). This isn't so much to save energy but to reduce damage. Recent power outages have damaged the amp in my sub & amplifier.
post #55 of 55
auto-on for me = never worry about it. it's drawing 1watt or so in stand-by.
