I have a Panasonic 65" VT30 and I am using a Denon AVR-3312CI and Direct TV HD DVR. I have the Direct TV DVR connected to the Denon with an Audio Quest HDMI cable and then I have the Denon running to the tv with an Audio Quest Coffee HDMI cable. The issue I have is the previous Denon receiver I had had Digital Optical inputs and so I used to run the Audio from the Direct TV DVR to the receiver with a Digital Optical which made the receiver automatically switch itself to the right audio settings based on the signal. My new denon has no Optical inputs, only 2 outputs, so I am running everything through my HDMI cables and I notice that the audio no longer switches, so I have to do it myself. Does anyone know what I need to do to get this to work through the HDMI? I have a 5.1 system installed with a subwoofer. As a side note, when I use my PS3 to play blue rays or games, the audio switches on it's own correctly and I have it connected the same exact way.
AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Why isn't my receiver (Denon AVR-3312CI) automatically detecting audio signal?
Featured Stories
Topics Discussed
Related Forum Threads
- Denon 3312CI Malfunctioning Last post on 5/19/13 at 10:27am in Receivers, Amps, and Processors
- OFFICIAL DENON AVR-3312CI RECEIVER OWNERS THREAD Last post on 4/27/13 at 5:06pm in Receivers, Amps, and Processors
- Denon AVR-3312 For Sale Last post on 4/15/13 at 7:03am in Audio Gear
- Zone 2 remote for a Denon avr-3312ci Last post on 4/13/13 at 4:04pm in Receivers, Amps, and Processors
- Is it worth the upgrade? Marantz SR5006 to Denon 3312CI Last post on 4/14/13 at 5:27pm in Receivers, Amps, and Processors
Gear mentioned in this thread:
post #2 of 7
10/14/12 at 7:36pm
- amirm
- Trader Feedback: 0
- offline
- 16,011 Posts. Joined 1/2002
- Select All Posts By This User
post #3 of 7
10/14/12 at 11:20pm
I don't understand what you mean when you say your AVR doesn't switch to the correct format and that you have to do it yourself. A satellite DVR will only output DD 5.1 or stereo PCM. If the DVR is sending PCM, you can't change it to DD 5.1 with a setting on your AVR. And, if it is sending DD 5.1, then the AVR will use correct decoder as long as the input is set to Auto, which is the default.
Sometimes the HDMI handshake with the TV will force the DVR to send stereo PCM instead of DD 5.1. Setting the HDMI audio output to AMP instead of AMP + TV will fix that problem.
post #4 of 7
10/15/12 at 8:17am
- Possumgirl
- offline
- 1,699 Posts. Joined 12/2008
I could be wrong, but I think the OP may be talking about HDMI-CTL. The Panny TV, PS3 & AVR all support CEC so the Denon switches to the correct input when the PS3 is turned on. Sat receivers don't support CEC, so he has to manually select that input. At least that's how I read it.
Don't understand the comment that the Denon doesn't have digital optical inputs. According to the specs for that model it has two. It does not have optical outputs.
post #5 of 7
10/15/12 at 8:59am
I apologize, I read the Optical jacks on the back of the DVR unit wrong, they are inputs, not outputs. What I was inquiring about was the receiver being able to detect the audio signal it is receiving and change the Surround Sound mode based on that. My older Denon used to do this when I was using a Digital Fiber Optic cable for the audio. I could visually see that the surround mode had changed based on the type of signal it was receiving from the source.
- Why isn't my receiver (Denon AVR-3312CI) automatically detecting audio signal?
Currently, there are 1908 Active Users
(464 Members and 1444 Guests)
Recent Discussions
- › Beam and Pole interruptus NOT - BIGmouthinDC and NYGiantsFan23... 1 second ago
- › WESTERN DIGI "MY BOOK" 1T DVR EXPANDER NOT RECOGNIZED BY MOTOROLA... 3 seconds ago
- › Cat.5E+16/4AWG Audio Combo Cable wired in house 22 seconds ago
- › Higher end avr vs lower end avr. 31 seconds ago
- › *Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread 41 seconds ago
- › Bass that can be felt? 1 minute ago
- › NFL Sunday Ticket on PS3 2012. Reviews. Thoughts 1 minute ago
- › Microsoft fires the first shot in the "NEXT" generation.... 2 minutes ago
- › IR after using slides vs IR in with out 2 minutes ago
- › HDMI+Optical in to HDMI Out 3 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
