AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Newbie Question: What do I need to buy: RG59 Cable for subwoofer?
post #1 of 6
Hello!
IF this is a repost, please kindly refer me to the appropiate thread.
I have a new house and media room, prewired for 7.1. I just hung the projector yesterday night. I need to hookup my subwoofer.
I have behind the wall plate (at both ends) a RG59 20AWG cable for the subwoofer. Just the cable, chopped off, no connectors, no RCA connectors, no nothing, just the cable.
In order to hook up my sub, what do I need and how do I go about doing it?
I have searched the forums and I think I am using the wrong terms. I need the idiots's guide.
I have multiple little coax male/male adpaters (I pulled them off the coax wall plates to make room to pass my speaker wires through).
I think I need a crimping tool, plus some sort of connector to attach the RG59 to an female RCA plug that then plugs into the Subwoofer and AVR.
I ran across this:
http://www.pimfg.com/ifaq/crimpfaq.htm
Is that it?
If so, what do I search for either at monoprice or partsexpress?
What if I want to have the RG59 terminate in the wall plate, and then have the subwoofer line in plug into the wall plate. Is it any different?
post #2 of 6
I would do (have done) F connectors on the Series 59 cable, with a short piece of 59 going from the wallplate to the device, with an adapter (FF-R) to plug it into the AVR and the sub-woofer.
post #3 of 6
Could you be so kind to let me know what I need? Is it a F type to RCA Female or F Type to RCA Female. I have a standard subwoofer, and it has the "female" plug on it (so does the receiver) Subwoofer cables have male tips at both ends. I searched monoprice and did not find a Ftype to RCA connector.
Sunil
post #4 of 6
Originally Posted by sksahai View Post
Hello!
I ran across this:
Is that it?
Looks good. Compression fittings are the modern solution and give me great performance.
The tutorial is a little tool-happy. I have great results with just a stripping tool and a compression tool.
The plastic compression tools seem to work out. I've used them and I noticed that the cable guy used one when I switched to Wowway.
They need to be sized for the cable, so don't try to use RG59 compression fittings with RG6 and vice-versa.
rca compression
http://www.parts-express.com/pe/showdetl.cfm?partnumber=092-496
Get a bulkhead RCA jack
http://www.parts-express.com/pe/showdetl.cfm?partnumber=091-1210
Drill an appropriate hole in the blank wall plate of your choice.
post #5 of 6
All of the connectors and adapters you need are available at Radio Shack. Female-Female F connector on the wall plate. F connector Male on the Cable in the wall. F Connector Male to RCA Female adapter on the end of an RCA Male to RCA Male cable for connecting between the Sub and the Wall plate. Pretty straightforward stuff.
post #6 of 6
Thank you! Going to be a Xmas break project!
  Back to Forum: Tweaks and Do-It-Yourself
