So I had heard about OpenELEC but was disappointed it wasn't updated for Eden yet. With version 2.0 imminent with all the Eden goodness, I decided to give release candidate 2 a try. Basically, it's a very lightweight linux install with XBMC installed and nothing else. I am amazed how well it works. It takes about five minutes to install, and it's working perfectly so far. It also boots very quickly and uses less resources than Windows. No more worrying about Windows updates, inadvertent notifications, problematic drivers, losing focus, etc. Honestly, unless you run external programs on your XBMC HTPC, I can't see why you would use Windows over this. After years and years of using HTPCs, mine finally feel like appliances. If you're having any issues with your current installs or are making an HTPC for the first time, I recommend giving it a try.
Update: OpenELEC 2.0 Final just came out (10/16)
Update 2: OpenELEC 3.0 released!
http://openelec.tv/
Edited by lockdown571 - 3/25/13 at 6:42pm
http://openelec.tv/
If I can't get this working I'll have to go back to XBMCuntu, which did work, but definately boots slower, and doesn't run as quickly on my underpowered Fusion build.
