Foxconn A3700 (this one)
4G DDR3 1333 RAM (pretty sure it was this one)
1 8G USB stick for the OS.
That is it. Installed OpenELEC 2.0 Fusion. I am borrowing my ADESSO ARC-1100 remote IR receiver from my main unit while I wait for EBAY delivery of an HP brand MCE receiver. I may move the OS from USB stick to a Class 10 SD card, but its not really necessary because it is working great as is, just a little slow doing library updates.
The only problem right now is a little quirkiness with wake from suspend. I tried all the BIOS setting options and it does not work consistently and sometimes locks up. Will try again with new IR receiver, but at this point I disable wake from USB completely and use the power button when I am going to use it. Not a problem for me.
I have mine hardwired Ethernet, so I have not used the wireless connection, can't tell you how well it works.
Edited by DanPackMan - 11/7/12 at 5:05am
