OK, in my search for RAID4 parity based protection utilities, I stumbled upon disparity. It is like SnapRAID, only simple enough that I can understand its command line. It is also still actively being worked on (albeit after a long pause). The next version will contain its own GUI, but for now you can either download the utility itself here:
http://www.vilett.com/disParity/forum/topic.php?id=94
Or download the GUI which also has the utility built in here:
http://student.fau.edu/pbryan/web/dsm/
I am going to remove SnapRAID and test this one out. Anyone currently using disparity?
