Having trouble re-installing 0237 code for Comcast. I did down load COMCASTDTAir Codeoverwite0237 50005500.zip file, this was a great overwrite the first time I used it , and it worked, now after doing a factory reset the 0237 code was no longer there, I removed the HDD set it all up to the pc same as I did the first time, used the .bat file, and I get overwrite failed, tried some of the other zip files just to see if they would work, no same failure, tried to install it via Wirns, (cp -f /name/storage/Photo/install/C0237fi.rid /name/system/user/mirror/sys-setup-gaea/data/irCodeset/C0237fi.rid) can't seem to get it work with the 0237fi.RID file in the replay photo/install file as directed. I have no clue how to overwite the HDD with a new ISO file or use Linux . Is their anyone out there that my have another work around.
AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › IR Code for Comcast DC50X DTA
