AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Yamaha RX-V673BL or Pioneer SC-1222-K
post #1 of 16
Greetings!
Need a new receiver with modern features, network support, and upconversion. Don't need a lot of wattage, and don't need booming bass. I just need something that will connect and switch Apple devices, TV cable box, PS3, Xbox, and my various other video gadgets . I especially don't want to get tangled in unexpected restrictions like "input A can only be played thru output B, and only every other Thursday"....
I have been reading relevant posts and reviews, and learned enough to understand these models are pretty good.
They are both are "on special" on various outlets, so this is a "value" question:
Yamaha RX-V673BL @ $420
..or
Pioneer SC-1222-K @ $600
TIA
post #2 of 16
Anyone?
post #3 of 16
Where did you see the V673BL for $420? The cheapest I've seen it was $599.99. I'm trying to decide between the V673BL and the Pioneer VSX-1122-k. I can get the 1122 for $450 at Best Buy by price matching newegg.com price, but I had a bad experience with the VSX-1022-k, and I'm wondering if it would be a mistake to go with the Pioneer. However, the $450 price isn't bad.
post #4 of 16
Newegg had a 72-hour coupon for 30% off, that made it $420, but it's no longer valid.
post #5 of 16
Which AVR did you end up getting if you don't mind me asking?
post #6 of 16
Because I am a dummy, I failed to pull the trigger in time for that coupon, so now I am still looking and hoping for another special or a coupon somewhere. Meantime, I have been scouring the web for reviews and feedback, and I think I'll stick with Yamaha.
post #7 of 16
Pulled the trigger.. V673BL is on special (with gift card) at Newegg for $389 shipped. Yay!
post #8 of 16
$389? I see it as $599 then you get a $210 gift card. Do they let you subtract the giftcard amount from the initial price or something?
post #9 of 16
post #10 of 16
That's what I figured, which is why I was curious about the $389 shipped number.
Might jump on this deal as well.
post #11 of 16
Well I'm definitely not going to spend $200 gift card money on wires. But Amazon has it for $399. Got one!
post #12 of 16
I had the Yamaha rx-v673 for a week and I returned it. Features were good, I liked YPAO and the sound quality produced was good. But I returned it. Here's why. It can only produce 90 watts per channel at 8 ohms and is not rated for 4 ohms. It would've been fried if I connected my Polk LSI15s. I purchased the Open box Pioneer SC-1222 on Newegg for $479 shipped. Here's why. The SC-1222 has Class D3 Amps which are way more powerful that the Yammy's amps and it produces 130 watts per channel at 8 ohms. More Importantly it is rated at 190 watts per channel at 4 Ohms. Now that's raw power to run the PolkLSI15 speakers which are power hoggers but beasts when it comes to sound quality. And the Pioneer SC-1222 has pre outs so you can connect an amplifier. I don't remember if the Yammy has Pre outs.
Why would you pay close to $400 for a Yammy when you can get a Pioneer that literally can power most high end speakers for $479 ( roughlty $439 + $38 tax +$1.99 shipping). Hope this helps.
post #13 of 16
what you fail to realize is that pioneer rates the power at 1khz instead of full bandwidth...so those numbers are inflated. reciever power is reciever power....that pioneer might have 10-15watts per channel more if your lucky. yea the pioneer is 4ohm stable, so that might be a benifit. did you try the lsi15's on the 673 before returning it?
post #14 of 16
Agree with your post. But 15 watts per channel more is a lot of difference. And the pioneer is rated for 4 ohms at 190 watts per channel. Receiver power is receiver power. Atleast it won't get fried by the the LSI15s. And no I didn't dare connect my LSI15s to the Yammy. I had intentions to return the Yammy and get my money back.
I know I need an amplifier but I can run the LSIs on the pioneer till budget is put aside for one. Well $79 is not a lot of money for the peace of mind that the receiver won't get fried..
post #15 of 16
15 watts per channel is literally nothing and won't make any difference. Especially in real world listening as opposed to how receviers are spec'd.
Edited by nodnerb - 4/26/13 at 6:15am
post #16 of 16
it's not just about 15 watts more. my friend have Yammy 675 and LSI15, went pretty hot when playing loud. I lend her my SC-1522-k (Costo deal of course), it stayed cool with even higher volume.
But of course that doesn't mean the Pioneer is better than Yammy, or class D is better than class A/B, but in case of 4 ohms speakers, there is not much of receivers under $1000 to choose from, unless you go with pre-out and amp without budget concern.
