NuForce launches the NuForce S3-BT, a new line of high-quality bookshelf speakers that sport Bluetooth 4.0.
Product Specs:
The NuForce S3-BT is available for $299 starting from October 31 from NuForce.com, several online stores and NuForce dealers.
NuForce, Inc., a leader in professional and consumer audio solutions, announces its S3-BT wireless Bluetooth loudspeakers. The NuForce S3-BT is a meticulously designed active loudspeaker that features the latest aptX® and ACC technology for clear, full-bodied, distortion-free audio streamed over Bluetooth.
Jason Lim, NuForce CEO: "With Bluetooth-enabled devices becoming the most common way to carry and listen to audio files, we at NuForce decided to create a speaker that would satisfy even our most discerning customers. By implementing the latest technology and focusing on custom design, we've successfully created speakers that deliver the most advanced audio performance from a Bluetooth bookshelf speaker today."
The S3-BT speakers are based on an essential, time-honored principle: good sound depends on intelligent design and superior materials. For example, the S3-BT's woofer employs a proprietary anti-resonance cone and powerful magnet assembly. Similarly, the tweeter consists of a custom-designed soft dome design for negligible distortion and smooth, natural sound. And, for the eye, the speakers' outer shells are wrapped in soft white or black leatherette.
The S3-BT's aptX Codec feature offers exceptional Bluetooth performance. However, for those who demand yet better sound along with convenience, we've included a set of analog inputs for connecting directly to a TV or other entertainment device. NuForce's own Air DAC wireless system* can also be connected to the S3-BT speakers for even higher quality wireless audio streaming.
Product Specs:
-Superior sound from mobile devices. Utilizes the latest AAC (iPod, iPad, iPhone) and aptX Bluetooth compression Codecs (Select Apple products* and Android devices) for CD-quality wireless audio
-Secondary analog inputs for integration with TV or other home audio devices
-Analog inputs can also be used for upgrading to NuForce Air DAC wireless system offering outstanding performance and negligible latency
-Elegant design wrapped in soft black or white leatherette
-Compact bookshelf size that fits any room or decor
-Wireless freedom - music playback from any Bluetooth device
-Proprietary anti-resonance woofer and custom-designed soft-dome tweeter
-Efficient Class-D amplification for crystalline sound and low power consumption
Speakers
-1" soft dome tweeter x 2
-3.5" composite paper cone woofer x 2
-Amplifier
-Maximum power output: 18 Watt x 2 RMS
-Harmonic distortion: < 0.5% 1 W 1 kHz
-Frequency response: 50 Hz - 20 kHz
-Signal/Noise ratio: > 75 dB
-Separation: > 45 dB
-Input/Output Speaker output on right channel unit: Five-way binding posts
-Speaker input on left channel unit: Five-way binding posts
-Analog Input: RCA jacks
-USB Charger Port: 5v, 1A output (strictly for charging mobile devices only, no audio/data transmitting)
-Bluetooth wireless connection: Bluetooth core version 4.0 with aptX , SBC, AAC codecs; A2DP and AVRCP profiles
-Dimensions: 7" H x 4.57" W x 7.48" D
-Weight: 5.51 lb. each
Included Accessories: (2) S3-BT Bookshelf Speakers, 3.5mm Stereo to RCA Cable, Interconnect Speaker Cable, AC Power Adapter
Speakers
-Amplifier
