AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Projector being at the back of the screen, can it be done?
post #1 of 2
Hello
At some areas of my house (outdoors) it would be more convinient to have the projector at the back of the screen.
Would we be able to see same quality, or always the projector should be at the front?
Sent from my NookColor using Tapatalk
post #2 of 2
Rear projection is definitely possible. Most projectors have settings to reverse the image. You need a transparent screen, but many companies sell that as well. The biggest thing you need is space to mount the projector behind the screen. Projectors require a fairly sizeable throw distance. Figure 12-14' for a 120" image.
The good news is that it doesn't need to be straight back. You can use a mirror mounted at a 45 degree angle to direct the picture toward the screen. However, all of this is fairly complicated and will cost more than front projection. This is why most folks will just go for a front projection system.
You might want to pop on over to the screen forum. There are several good threads there on this topic.
